Author Topic: Are longer shim bolts required with the use of drop springs?  (Read 5589 times)
Offline chevymotocross
I'm in the process of lowering the front of my 87 silverado along with new suspension parts (tie rods, balljoints, etc).
I noticed the stock setup already has lots of shims. With the addition of 2'' drop springs, I will need even more shims. I don't think the stock upper control arm studs will be long enough to compensate.
I read somewhere that the stock studs can be knocked out and replaced with longer 1/2x4 Grade 8 bolts.
Is this needed for a 2'' spring and 2.5'' spindle drop?
Moog also sells an offset UCA shaft but I would rather go the bolt route so I don't have to dissassemble the UCA.
1987 Chevy Silverado 2wd SWB: 305 TBI, 700r4, dual exhaust, tbi mods, k&n filter, belltech sway bar
Re: Are longer shim bolts required with the use of drop springs?
« Reply #1 on: July 14, 2010, 01:11:49 pm »
more shims, yes.  longer studs no.
« Reply #2 on: July 14, 2010, 01:20:23 pm »
I guess I'll give it a try. Just seems there isn't much thread left for extra shims. If alignment guy tells me so, I'll have to add longer studs at a later time.
Offline stavendirtbike
« Reply #3 on: July 15, 2010, 04:01:04 pm »
I replaced them all today with longer grade 8 bolts. Atleast now I know 100% the alignment shop can have no excuse for not getting the camber correct. Plenty of room for shimming.
Offline txswb87
« Reply #4 on: July 18, 2010, 09:02:41 pm »
Drop spindles dont change your front geometry,everything should work fine mine did.
