Author Topic: Anyone lifted a 2wd to stock 4wd height?  (Read 19159 times)
Offline MarkS
« on: July 14, 2010, 07:10:35 pm »
I have a bone stock 2wd and don't need 4wd but like the ride height and look of the 4wd's. I prefer suspension lifts versus body lifts but maybe? General concerns doing this mod?
Offline velojym
Re: Anyone lifted a 2wd to stock 4wd height?
« Reply #1 on: July 14, 2010, 07:55:16 pm »
Just looking at mine, it seems like leveling the truck will have pretty much that effect. Some folks have used 1 ton springs up front, and there are purpose-built lift springs, too, IIRC.
Online zieg85
« Reply #2 on: July 14, 2010, 07:58:28 pm »
Going with big block springs up front will not equal stock 4x4 height but will safely lift it and still a reasonable alignment can be done.  I wouldn't body lift one, I think it wouldn't look right.  My $.02
Offline three8six
« Reply #3 on: July 14, 2010, 10:24:28 pm »
I would body lift it and drop the rear an inch to level it out but thats just me. Just cover the hole in between your frame and bed, I hate to see daylight there.
Offline Da67goatman
  • Burban
« Reply #4 on: July 14, 2010, 10:29:34 pm »
I did that with big block springs up front and add 2 leaves in rear.  Then its all about wheels and tires to get the 4x4 look.
<Pitcrew>
Offline MarkS
« Reply #5 on: July 15, 2010, 01:54:06 pm »
How was the ride after?
Offline Da67goatman
  • Burban
« Reply #6 on: July 15, 2010, 02:35:34 pm »
It rides nicer then my moms 2002 Yukon XL and it has coils in the back.
<Pitcrew>
Offline markdilljr
  • Me on Hopper "Covered"
« Reply #7 on: July 20, 2010, 03:31:00 pm »
I put 1 ton springs in the front and HD leafs in the rear ( the 56" ones ) then put 31x10.50x15 it looked pretty close to 4x4 height
Ride Rank, Make Bank
Offline Grim 82
« Reply #8 on: July 20, 2010, 04:26:39 pm »
Your truck looks awesome now but the HD springs in the rear created this condition:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=16747.0
MarkS, I would add some leafs or use blocks.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #9 on: July 20, 2010, 05:26:30 pm »
Mines a 3/4 ton and already had HD rear springs, but NON-HD front springs.  When I put HD coils up front I had to buy 1.5" lift blocks for the rear.
Offline Swims350
    • Cars and trucks
« Reply #10 on: July 20, 2010, 06:03:24 pm »
Well we had a 76 put air shocks on the back and coil spring spacers in the front and rode on 31 10.50's all the time. It sat up some, not sure if it's as tall as a stock 4x4 or not but rode good. A bit stiff in the back if you had it aired up to match the front and were running empty in the bed.
www.cardomain.com/id/benwa454
Offline markdilljr
« Reply #11 on: July 21, 2010, 10:46:16 am »
Thanks,Yea with the rear HD springs they rested on the shackles, switched back to standard springs but you can add blocks to bring the rear up. The ride was very rough with it lifted like it was so I decided to go for a slightly lowered look. One thing to watch out for, when I had the bigger coils in it my upper control arms rested on the top of the coil pocket ( cross member ) which made the ride stiff and it wanted to jump every little bump
Offline modular93fox
« Reply #12 on: July 22, 2010, 09:03:10 pm »
This isnt the site I was thinking of but its the same part but in a kit. Its a ball joint spacer that gives you an extra 1 or 1.5 ". The spacer goes on the upper arm and simply use longer bolts.
http://universalcarlifts.com/product_info.php?cPath=30_101&products_id=121
clint
1987 5.3 4l60e Silverado - daily driver with A/C,P/W,P/L,TILT, HID projectors & 13.8" Rear Disc Brakes
A poor man buy's it twice
