Author Topic: 74 chev pu backup light  (Read 5464 times)
Offline usaeagle6
« on: July 16, 2010, 01:12:14 pm »
Where is the backup light switch located on this truck?
Also, I do not see a backup light fuse on the fuse panel.  Does it not have one or is it combined with some other fuse?
The tail lights and turnsignals work, but the backup and licence lamp do no.
Any suggestions?
Re: 74 chev pu backup light
« Reply #1 on: July 16, 2010, 01:49:06 pm »
Are the bulbs good?
« Reply #2 on: July 16, 2010, 11:49:23 pm »
Check your bulbs if they check out try this neutral safety switch
for automatic its on the steering column
Offline DnStClr
« Reply #3 on: July 17, 2010, 03:29:28 pm »
and it's a pain to get to..
Don
87 Chevy Silverado
« Reply #4 on: July 17, 2010, 03:31:41 pm »
I recommend a manual. Surf Ebay for the factory manual. you can get them brand new, or used. Even a Chiltons/Haynes will be sufficient for most things.
« Reply #5 on: July 17, 2010, 04:56:48 pm »
  On my 74 with a sm465, it is on the transmission, drivers side up toward the top of the transmission.
