Author Topic: 2" drop spindles whith stock rallys?  (Read 18338 times)
Offline c10chevy81
« on: July 18, 2010, 01:25:29 pm »
I was wondering if anyone has used 2inch drop spindles with 15x8 rallys. Some people say you can and others say you have to run atleast a 17in wheel, so if anyone has ever done this or knows what kind of spindles will work i would appreciate the help. Thanks
Offline rwhit57
Re: 2" drop spindles whith stock rallys?
« Reply #1 on: July 18, 2010, 02:43:18 pm »
It works fine. Yes the bigger wheels might look better to some, but it's a personal preference thing if you ask me. Heres a pic of my 85 with the coils cut, basically the same thing. I have it torn it apart right now putting A-frame bushings and spindles and coils. It will sit about the same. I'm going back with the 15x8 Rallyes and 275/60-15s to retain the look.
Randy from Okla
Whoever said "Money can't buy happiness" has obviously never seen a speed shop!
Offline greatdane
« Reply #2 on: July 18, 2010, 08:17:02 pm »
Are those 275/60/15x8 on there in that pic? Thats the tire size I am thinking about with rallys also. Will they go on the front and still turn with a 2.5" drop?
'74 AMC Matador 2dr Coupe
Offline txswb87
« Reply #3 on: July 18, 2010, 09:00:01 pm »
All you need is the right back space. If you run the stock rally you should be alright. I put 2" drop on mine but my wheels have about a 4' back space and almost dont fit, If I had weights on the outside they would hit the tierod end. I also had a problem with the spindle hitting inside the wheel, figured out that the edge where the brake caliper mounts needed to be ground down just abit tight fit but they work. I do have aftermarket wheels not stock.
Offline rwhit57
« Reply #4 on: July 18, 2010, 10:30:04 pm »
Yes, those are stock 15x8 rallyes with 275/60-15 tires. I have used them with 2-1/2 spindle and 1' coil, and no rub issues. A stock rallye has a 4-1/2" back spacing. The truck in the pic has 2 full coils cut and drives good I just can't quite get the camber right so I'm going with the spindles and coils, on this truck I have the shackles and hangers, but thinking anbout the flip kit if it sits too high in the back.
Randy from Okla
Offline team39763
« Reply #5 on: July 19, 2010, 02:14:40 pm »
I have 2.5" drop spindles in mine with stock rallye wheels.  The only issue I had was with the brake line, just had to bend it out of the way.
Offline modular93fox
« Reply #6 on: July 22, 2010, 08:58:00 pm »
I had the McGaughys 2.5" lowering spindles and they barley fit the stock 8" ralleys. I mean lock to lock would take part of the lead weight off (it would shave it). So what I did to solve my problem... dont turn lock to lock, becuase when I did, I knew I turned too far. With the wheels strait, plenty of clearance.... its jut lock to lock
clint
1987 5.3 4l60e Silverado - daily driver with A/C,P/W,P/L,TILT, HID projectors & 13.8" Rear Disc Brakes
A poor man buy's it twice
Offline c10chevy81
« Reply #7 on: July 23, 2010, 10:33:20 am »
alright guys thanks for all the help and the fast replys..i appreciate it.
Offline bigdogck
« Reply #8 on: July 25, 2010, 08:53:19 pm »
I have 3in spindels at the most grind the lower control arms around the lip
Offline three8six
« Reply #9 on: July 26, 2010, 10:15:22 am »
I had bad luck, I could not put my 15's on and drive with the after I put the McGaughys Spindles on my truck, I even had to trim to use a 17 inch wheel. with the same backspacing.
