General Discussion
Brake Lines
Topic: Brake Lines (Read 4928 times)
Rutt Roe
When in doubt, Floor it!
Brake Lines
July 19, 2010, 08:21:49 pm »
I bought a new booster and master cylinder for my 82 K-10 I was wondering does it mater witch line goes where into the master cylinder, cuz i noticed on my old one, the bigger size bolt was in the back, now its in the front on the new one. Whats the deal? They give me the wrong one? Old one was steel, new one is plastic.... I got the brakes all blead, and the pedal feels hard, Im not about to drive this till I know, lost brakes in this once, dont want it to happen again
Thanks guys
Novadiecast
Re: Brake Lines
July 19, 2010, 08:42:51 pm »
I am pretty sure you got the wrong one.
1985 Crew Cab dually project soon to be SRW Short Bed
Blazin
Blazin new trails!
Re: Brake Lines
July 19, 2010, 08:57:59 pm »
Yup you need the metal one.
Rutt Roe
Re: Brake Lines
July 19, 2010, 09:07:52 pm »
I ordered it online from advanced auto. Why do they even list this plastic one for this truck, if it isn't the right one?
Re: Brake Lines
July 20, 2010, 06:08:10 am »
The only thing I can see is if it’s a diesel engine it has a metal cylinder if its gas it has the plastic
Rutt Roe
Re: Brake Lines
July 29, 2010, 05:52:28 pm »
Ok I bought the right master cylinder, bled the lines, took the truck out and the pedal went to the floor again.......
Whats going on? What else could it be?
eventhorizon66
Re: Brake Lines
July 29, 2010, 08:37:14 pm »
Did you bench bleed the MC before installing? Are your calipers/wheel cylinders leaking like a sieve?
'85 C10 SWB 350
700R4
TKO600
Rutt Roe
Re: Brake Lines
July 30, 2010, 05:37:18 am »
I did bench bleed the master, and theirs no leaks
General Discussion
Brake Lines
