Author Topic: trouble with identifying my 350  (Read 6423 times)
Offline timradzik
« on: July 19, 2010, 10:08:36 pm »
i have a 1980 chevy c 10 4x4 with a 350. i am looking to do an engine swap. i have two questions. 1. how many year difference can i go with from the original motor. example if i pull an engine from a 73 chevy c 10 or gmc. 2. is the 350 engine that is mated to a tmh350 transmission a 2 or 4 bolt? if anyone can help me out it would be appreciated.
Re: trouble with identifying my 350
« Reply #1 on: July 20, 2010, 06:17:54 am »
C10 4x4 ??? something aint right but if its a k10 more than likely its just a 2 bolt main the only way to tell that I know of is pull the pan off. What trans it’s mounted to don’t mean anything. You can use any motor just the dip stick changes in the older years from passenger side to driver’s side
Offline Swims350
    • Cars and trucks
« Reply #2 on: July 20, 2010, 10:18:12 am »
you could basically use any engine in your truck up to now really. the old school blocks up to the 90's bolt up, stock and then the ls1 type engines and such have adapter plates. SO if that's what you wonder basically anything, but to give you a guestimate, up to 98 chevy or gmc 2wd or 4x4. 86 and up use a 1 piece rear main seal, so make sure to use a flywheel/flexplate that goes with the motor, or buy one that fits it.
You could go way back as well, almost to the start pretty much of chevy v8 like around the 50's 60's or something. As mentioned the oil dipstick switches sides but there's no worries there, they'll physically bolt up, the newer block though some cannot use the block mounted fuel pump. You can make it work though, with electric pumps or something, so basically you are limited only by your skills and what you want or are willing to change. As for an almost direct bolt in drop in deal, I'd say 73-87 or even older, like maybe to 67 or so.
www.cardomain.com/id/benwa454
Offline jaredts
« Reply #3 on: July 20, 2010, 11:41:27 am »
I'm not really up on it, but didn't the heads get drilled differently for accessories on later motors?  Not sure if that's tbi heads or vortec era stuff.
Offline Swims350
    • Cars and trucks
« Reply #4 on: July 20, 2010, 02:20:14 pm »
I aint really sure myself I got an 88 tbi motor and I THINK all the holes are there for the older style accessories. If not then convert to serp. or use the newer bracket setup maybe.
« Reply #5 on: July 20, 2010, 06:30:41 pm »
Holes are the same on TBI trucks.
« Reply #6 on: July 20, 2010, 06:59:15 pm »
If they have bolts they are the same. Older double hump / heads didn't have bolt holes at all. But they are all interchangeable
Offline timradzik
« Reply #7 on: July 20, 2010, 10:18:18 pm »
thanks for all of the help gents.
« Reply #8 on: July 20, 2010, 10:20:19 pm »
Point of intrest. Some double hump heads have bolt holes.
« Reply #9 on: July 20, 2010, 11:40:05 pm »
didn't know that, knew you can drill them but its a little hard but nice to know that
