Author Topic: Voltage Drop  (Read 6211 times)
Offline TxFiddler
Voltage Drop
« on: July 20, 2010, 10:34:04 am »
What causes the voltage on the guage to drop when the blower fan is on high at engine idle?  Also, the pwr windows operate slowly when the fan is on high and the headlights dim.  Would a new alternator correct this?  Possibly a 100 amp?  Thanks.
80 C10 2wd / 427 BigBlock / 700R4 / 3:42 Eaton Posi LSD / 770 cfm Holley Street Avenger / Doug's Headers / MSD ProBillet Distributor / Champion 3 row Radiator
Offline jaredts
Re: Voltage Drop
« Reply #1 on: July 20, 2010, 11:03:22 am »
There may be other things to consider, but here are a couple:  Make sure your idle speed isn't set too low, and make sure you have all the required grounds (in good condition) especially from the engine to firewall and battery to radiator support.  Some dimming of headlights and slow windows should be expected, but should be minor.  If everything's in good shape a bigger alternator should help, but again isn't normally required.
Offline TxFiddler
Re: Voltage Drop
« Reply #2 on: July 20, 2010, 11:33:41 am »
Hey thanks jared.  I'll check out the connections and see if it helps.  Probably some corrosion since the truck is ONLY 30 yrs old.
Offline jaredts
Re: Voltage Drop
« Reply #3 on: July 20, 2010, 11:42:20 am »
Longest lasting trucks on the road!   ;D
Re: Voltage Drop
« Reply #4 on: July 20, 2010, 07:13:36 pm »
Give some numbers ex. Volts before and after and rpms
Offline TxFiddler
Re: Voltage Drop
« Reply #5 on: July 20, 2010, 07:18:14 pm »
Irish, just going by the guage, normal reading is just a hair passed the 13.  Especially on a hot, Texas day, at idle with blower on high, the guage is almost, but not quite touching the red on the low side.  I dont have specific readings, just whatever the guage reads. Thanks.
Re: Voltage Drop
« Reply #6 on: July 20, 2010, 11:47:15 pm »
Norm should be around 14-16 if you have a volt tester just put it on the battery and see what it says. Also sounds like a week alt I would take the whole truck to auto/advanced and get them to do a charging system test on it. make sure your battery connections are clean and tight
