Author Topic: GM Part Number thread....  (Read 3944 times)
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« on: July 23, 2010, 09:07:28 am »
I was wondering if we ought to have a place to put GM part numbers for those of us who want to be able to find GM parts, but can't find out what the Part numbers are...  I thought about this because I needed a new throttle cable and couldn't find the GM number for it, but then after searching for the number I remembered I had a new GM cable in the basement...  I lucked out but maybe when we get GM parts we could put the Part Number, year and description on here to help others out...
(this could be made into a list later or something)..  Just be as descriptive as you can so others could use your info to decide if that parts right for their particular truck.
Something like this:
1978 Chevy C20, 350sb  Throttle Cable
GM PN#01259333
1978 Chevy C20, Manual Window Regulator LH
GM PN# 14027431
1978 Chevy C20, Manual Window Regulator RH
GM PN 14027432
Just an idea...   Though I'm sure the implementation needs some help... ;)
Not all parts have to be listed, like an OE battery nobody cares about, Just stuff that only GM can make well, Like body parts and Throttle Cables, etc....
If nobodys wants to make the list, I could do it from you guys' part numbers, and we could put it in the technical pages section or whatever.
« Last Edit: July 23, 2010, 09:27:18 am by 78 Chevyrado »
Offline bfofish
Re: GM Part Number thread....
« Reply #1 on: July 23, 2010, 11:06:03 am »
I think that would be a great idea,when I get some time I will get some #'s together to add to the list.There have been a few times I needed a GM # to locate a part,this would have saved a lot of time.
  • Z62 ON-ROAD
« Reply #2 on: August 03, 2010, 06:00:27 pm »
Anybody know the PN for the headlight switch in the dash for a 78 C20?
EDIT:  I found the GM Part Number.
7 Terminal Headlight Switch - PN# 19106995
8 Terminal Headlight Switch - PN# 01995179
Floor Headlight Dimmer Switch - PN# 12338706
« Last Edit: August 08, 2010, 10:33:41 pm by 78 Chevyrado »
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #3 on: August 03, 2010, 09:34:23 pm »
you can enter then info on this site...
http://www.gmpartsdirect.com/catalog/frameset.cfm
