Author Topic: tri-y headers..Doug Thorley  (Read 19217 times)
Offline frotosride
    • WFO CONCEPTS
« on: July 23, 2010, 09:26:37 pm »
Doug Thorley, Anyone out there running these. I know that they make good low end torgue from experience so I'm not looking for an alternative. They are going into '87 silverado 4x4 w/ 383stroker, 700r4 and np208(unfortunately). They say that they are for the specific truck but anyone have any clearance  problems either from tranny, steering, fenders, x-fer case or ground clearance issues?
Re: tri-y headers..Doug Thorley
« Reply #1 on: July 24, 2010, 11:09:29 pm »
I have a set and I love them. No clearance issues at all.
Offline hogdaddy
« Reply #2 on: July 25, 2010, 09:23:40 am »
I run them also no issues whatsoever.
Offline eventhorizon66
« Reply #3 on: July 25, 2010, 12:26:20 pm »
I run them without any issues, but my truck is a 2WD.
BTW Chris (Captkaos), the owner of this site, is a vendor for Doug Thorley.  If you are buying new, talk to him first.
'85 C10 SWB 350 700R4 TKO600
« Reply #4 on: July 25, 2010, 06:19:12 pm »
One reason I like them is the coating has never gone bad. Another is the flanges are super thick, smooth, and straight. Never had an exhaust leak.
Offline Grover 1
« Reply #5 on: July 25, 2010, 08:49:38 pm »
Beastie, are your headers ceramic coated or silver ceramic and can you explain the difference?  Can you access all the spark easily?
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
And here I sit so patiently
You have to pay to get out of
« Reply #6 on: July 25, 2010, 09:28:21 pm »
I dont remember what coating, but they are chrome looking. The plugs are easy enough to access, as good as your going to get, really. Just a plug socket, extension, and maybe a wobbler. The only thing I didnt like was the PS side collector dumps at an angle, rather than straight back. I guess the reason is because of 4wd, but if I had known, I would have ordered the 2wd because there wouldnt have been a clearance issue on my truck. It actually would have been perfect. The only reason I complain about it is because I had built my own exhaust for it and getting it to curve back up was a problem. But an exhaust shop wont have a problem.
Offline frotosride
    • WFO CONCEPTS
« Reply #7 on: July 26, 2010, 01:55:24 am »
Well thats settled. plenty of reviews for me. Beastie, i paln doing my exhaust myself as well so would you recommend getting the 2wd version. with sas i don't how it would get in the way that much. I take it ceramic coated is highly recommended.
Offline frotosride
    • WFO CONCEPTS
« Reply #8 on: July 26, 2010, 02:00:22 am »
Even, thanks i will try to send chris (Captkaos) a message and pray for some help.
« Reply #9 on: July 26, 2010, 11:56:04 am »
I would call Doug Thorley to see what the differences between 2 and 4 wheel are. IF the PS collector dumped in the same spot and angle as the DS, I would have done it. It would have been a perfect shot to go past the transfer case, over the crossmember. But I got it to work so im fine with it.
« Reply #10 on: July 27, 2010, 02:54:34 pm »
I didn't get an email or PM on this but what is the actual application you are looking for?
Offline Grover 1
« Reply #11 on: July 27, 2010, 04:03:54 pm »
Chris, I'd like to know if they will fit on my 78 Silverado.  It's got 2-1/2" drop spindles in front.  My Hookers make some spark plugs next to impossible to get to.  Also, do you know the difference between ceramic and silver ceramic coated headers? - Thanks, Mark
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
« Reply #12 on: July 27, 2010, 10:57:59 pm »
If they fit my '85 perfectly, I can't imagine why they wouldn't fit your '78.  I am running Thorley 300Y headers and can get to every spark plug with a socket, though it is tight in some spots so I like to wrap my socket and extension in painter's tape to prevent scratches.  My understanding is that the chrome finish is for appearance and corrosion protection only, while the ceramic silver adds the benefit of heat reduction (though it doesn't look as nice as the chrome finish).  My headers are ceramic coated and unless my memory is failing me, my underhood temps seem to have gone down when compared to stock manifolds.  These are quality headers, but they come with cheap gaskets.  I suggest using quality copper gaskets at both ends of the header.
« Last Edit: July 28, 2010, 12:46:52 pm by eventhorizon66 »
Offline frotosride
    • WFO CONCEPTS
« Reply #13 on: July 28, 2010, 09:06:03 pm »
'87 silverado 4x4 sbc swirlport heads.383 stroker.
« Reply #14 on: July 29, 2010, 02:41:49 pm »
Factory Vortec Swirl port or aftermarket?
