Author Topic: post your engine pics*  (Read 7931 times)
Offline greatdane
« on: July 26, 2010, 04:51:54 pm »
I need engine pics to help me know were to hook everything up on mine! Also we all would just like to see your pics! Post pics from all angles I will need all the help I can get! 8)
'74 AMC Matador 2dr Coupe
Offline Swims350
    • Cars and trucks
Re: post your engine pics*
« Reply #1 on: July 26, 2010, 05:52:19 pm »
350 in the 84c10
305 that was in it...
305 while it was in the truck..
The 305 in the 84 when it was bone stock.
The same 350 from above but in the 76 when we first buit the 350.
The same 350 in my 85 mcss, after the 76 but before the 84 c10 got it.
The 350 we built for the 86 k10 we had.
305 that was in it.
As for hookups unless you got smog stuff it's easy, dist. bat wire, alt. wiring, fuel line, starter and solenoid wires, ground wire and straps if they are any, vac. line for the auto if it's th350 or 400 and kickdown cable if 350 or tv for 700r4 and such, power brake vac. if you have one, pcv, vac. adv. for dist. if you have one, and that's really about it.
www.cardomain.com/id/benwa454
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: July 26, 2010, 06:35:58 pm »
my old 350 showing vacuum lines on a '79...
www.delbridge.net/vacuum.html
my 383 www.delbridge.net/install.html
Offline rwhit57
« Reply #3 on: July 26, 2010, 10:57:31 pm »
Before and after a few new pieces and some paint.
Randy from Okla
Whoever said "Money can't buy happiness" has obviously never seen a speed shop!
Offline Layne
« Reply #5 on: July 30, 2010, 01:30:46 am »
Offline fitz
« Reply #6 on: July 30, 2010, 09:03:41 pm »
This is my SB 400 with TPI on it.
This is the oil pan with a rod sticking out.
