Author Topic: Pull Strap Problem  (Read 5271 times)
Offline Wilymakeit
Pull Strap Problem
« on: August 01, 2010, 09:16:56 pm »
1986 Chev SWB 4x4, I purchased a set of door panels that have the pull strap, when I installed the door panels and aligned the pull strap holes to bolt it onto the door, the right side hole was there but it is non threaded, I cannot see how it would be possible to slide a threaded clip over this hole as there is 3 inches of metal in all directions, the left hand hole ends up in the large square wide open area of the door, the only possibility I can think of is a bracket that bolts onto the frame of the door that has the 2 straps holes built into this bracket, can anyone tell me if there is a bracket, or it is clips or something else, would appreciate any help in this matter.
Thank You
Re: Pull Strap Problem
« Reply #1 on: August 02, 2010, 02:18:50 pm »
Can you get pics? There should be a 45* bracket for the rear.
Online Captkaos
« Reply #2 on: August 02, 2010, 02:24:46 pm »
sounds like you're missing the bracket in the door shell opening.
Offline Wilymakeit
« Reply #3 on: August 03, 2010, 07:10:59 am »
Thank You  that is what I was trying to figure out, a few people said it was clips but that made no sense to me, I thought it would have to be a bracket in order to bridge the large opening in the door, thanks for confirming it is a bracket that I am looking for
« Reply #4 on: August 03, 2010, 12:54:18 pm »
Yup, when you look for the bracket, get the clips if you dont have any.
