Author Topic: heater  (Read 12082 times)
Offline 74OrangeCrush
heater
« on: August 03, 2010, 11:53:11 pm »
I have a 74 stepside and can not get it to stop blowing hot air out, all of the cables are free and move properly is there something that could be stuck that I am missing?
Re: heater
« Reply #1 on: August 04, 2010, 01:12:39 am »
A door could be stuck open. The fan will always be on, so you will always have airflow. Think about dropping your inner box and cleaning it out. Its fairly easy. Might be a good time to swap out the heater core anyways. Its cheap, so its worth doing in the process.
Offline 1980c10
Re: heater
« Reply #2 on: August 05, 2010, 11:30:34 pm »
I have the same problem with mine. I'm actually considering putting in some inline valves on the heater hoses so I can shut them off on the hot days and open them up when I might want the heat.
Offline Swims350
    • Cars and trucks
Re: heater
« Reply #3 on: August 06, 2010, 09:54:15 am »
yea alot of gm's the fan keeps running I think I'd wire the sucker to a seperate inline switch before the regular switch or resistor whichever is needed to cut power and keep it from running until you flip that switch then turn on the heater by the factory switch.
www.cardomain.com/id/benwa454
Re: heater
« Reply #4 on: August 06, 2010, 08:10:32 pm »
Im with you beastie I live in Missouri and the last couple of days the heat index has been around 100-105 luckily it is a short drive to work
Re: heater
« Reply #5 on: August 06, 2010, 11:12:34 pm »
I unplugged my fan from under the Hood but due to vents its not a breeze of hot air but just hot air that u still feel
Offline 1980c10
Re: heater
« Reply #6 on: August 08, 2010, 11:24:52 pm »
thanks irish. I will try that. I don't know why it didn't cross my mind to just unplug it for the summer since mine is a non a/c truck.
Offline SeanK10
  • 79 K10
Re: heater
« Reply #7 on: August 09, 2010, 07:41:00 pm »
I had to do the Same thing haha,,it was a easy fix and Definately worth it
79 K10:350, Th350 6in. Susp. 3in. Body 38.5 in. groundhawgs......I welcome Criticism
Offline bobcooter
  • 1979 Scottsdale C-20
Re: heater
« Reply #8 on: August 12, 2010, 03:38:24 pm »
I've done that before. Works pretty well. I would open them every so often to circulate the water and coolant.
Offline howlinwolf
Re: heater
« Reply #9 on: August 12, 2010, 08:25:34 pm »
only need 1
78 Chevy Custom Deluxe flatbed, PROPANE POWERED
Offline bobcooter
Re: heater
« Reply #10 on: August 13, 2010, 02:26:39 pm »
That's what I did. Put a valve in the line going to the heater.
Re: heater
« Reply #11 on: August 16, 2010, 05:45:30 pm »
The fan running constantly was a "feature" on the trucks.
