Author Topic: sending unit replacement.  (Read 3411 times)
Offline ngarman123
« on: August 06, 2010, 10:05:19 am »
ok so i am replacing my sending unit and the one i bought is facing the wrong way. if you line up the 2 "keys" with the ring in the tank the ports are facing away from the frame. can i cut one of the tabs off and turn it 180? i dont think it should effect the float being 180 out maybe 90 degrees but i am not sure? any input
« Last Edit: August 06, 2010, 10:09:44 am by ngarman123 »
Offline jaredts
Re: sending unit replacement.
« Reply #1 on: August 06, 2010, 11:40:53 am »
Sounds like you just need to return it and get the right one.  Left and Right tank units are different.
« Reply #2 on: August 06, 2010, 11:28:08 pm »
X2
