Author Topic: Drive Shaft issues  (Read 10624 times)
Offline howlinwolf
Drive Shaft issues
« on: August 11, 2010, 11:37:56 am »
well, my poor truck has been down for a bit, because of the driveshaft.  Im looking for a place to ORDER a yoke, because the one that is on there is bent and doesnt slide, therefore killing ujoints.  I havnt been able to find a driveshaft or yoke, and im trying to locate one.
its about 1 and 3/4 inches of tube, outside. 16 spline. just give me a link for a website to order one pleasssseeee
78 Chevy Custom Deluxe flatbed, PROPANE POWERED
Offline team39763
Re: Drive Shaft issues
« Reply #1 on: August 11, 2010, 12:55:23 pm »
I usually go to summitracing.com and put in the correct info/follow the links for my truck.  I'm not sure what truck/trans you have, but I'm sure you could find what you're looking for on that site.  Then maybe use that info to buy it somewhere else at a better price.
http://www.summitracing.com/search/Department/Drivetrain/Section/Driveshafts-Couplers-Yokes/Part-Type/Yokes/Yoke-Location/Transmission/?Ns=Rank%7cAsc
I hope that helps.
Offline howlinwolf
« Reply #2 on: August 11, 2010, 12:57:12 pm »
thanks. im not sure exactly what the breakdown is, but its a 78 chevy halfton, 350, 4 speed, 4 wheel drive with lockout hubs up front.
Offline team39763
« Reply #3 on: August 11, 2010, 01:04:03 pm »
I looked, but I couldn't find exactly what you needed either.  Maybe one of the more experienced members will chime in and help you out.
Offline howlinwolf
« Reply #4 on: August 11, 2010, 01:06:07 pm »
my driveshaft has the slip joint in the shaft, and the ujoints bolt to the transfer case, and to the rear end.
« Reply #5 on: August 11, 2010, 09:03:42 pm »
I might be able to find one around let me check it will take a couple days since ill look at my buds stuff also and see what I can find
Offline howlinwolf
« Reply #6 on: August 11, 2010, 09:29:10 pm »
awsome. i have another lead as well, but the more the merrier
Offline howlinwolf
« Reply #7 on: August 12, 2010, 08:27:34 pm »
any hits?
« Reply #8 on: August 13, 2010, 03:17:50 pm »
Not yet bud haven't been to my buds house yet I know we have at least 2 sm465 so I know we have drive shafts for it just a matter of going over there but if I got off tonight ill check in the morning for ya. I know its not transmission specific but I know I seen the slip shaft
« Last Edit: August 13, 2010, 03:19:51 pm by Irish_Alley »
Offline howlinwolf
« Reply #9 on: August 13, 2010, 07:30:01 pm »
ill take pics
Offline howlinwolf
« Reply #10 on: August 14, 2010, 08:25:05 am »
here are some pics of the end of the driveshaft
« Reply #11 on: August 19, 2010, 11:19:08 am »
Didn't find anything he's even looking for one. But we did find one off a 2 piece shaft that might work for him but it was like a 32 spline I would check a yard and see what you can find
Offline howlinwolf
« Reply #12 on: August 19, 2010, 12:55:26 pm »
ive been looking all over the place. im about to take it all to a drive shaft shop in st louis called Driveshafts Unlimited. Its almost 400 bucks for a new one, but im gonna see what it will be for a yoke, u joints and a balace. hopefully its not over 150 bucks.
« Reply #13 on: August 20, 2010, 12:41:30 pm »
  If you take to the driveshaft shop and find out what you need and don't like the price they quote you, you can google driveshats on the web and a ton of them come up.  Then pick one you like and order.  The hardest part is finding out size, and what you need to order so you get the right parts.  Good luck.   Tom
Offline howlinwolf
« Reply #14 on: August 21, 2010, 08:08:26 am »
i know what i need, its just the yoke. but i cant find the exact one.
