Author Topic: 79 4x4 fleetside doors  (Read 3834 times)
Offline lpapa15
  • 1979 k10 silverado
« on: August 14, 2010, 10:32:25 am »
I am considering buying a 76-80 blazer or suburban and parting it out for my 79 fleetside k10 Cheyenne.  Are there any complications, warnings or any advice for that idea?  I want to use the doors, steering column, guage cluster and dash..  any help would be awesome.... thanks
« Last Edit: August 14, 2010, 07:48:48 pm by lpapa15 »
Re: blazer/suburban parts to k10?
« Reply #1 on: August 14, 2010, 02:45:06 pm »
All the same except for the early convertible blazers to 80 will interchange with your 79.  Doors are slightly different up to 76 I believe but someone with the hard facts will chime in...
Re: 79 4x4 fleetside doors
« Reply #2 on: August 15, 2010, 08:16:00 am »
The doors are a direct bolt on from 73 up, except the full convertable top Blazers as allready mentioned. The interior panels are different, the shape of the vent window is a little different at the very top.
As for the gage cluster, and steering column there are some little differences from year to year in the pin position where the wiring plugs in. Can't remember exactly but around 77, 78ish they changed from a mechanical oil pressure gage to an electric one. If you are changing it to get away from idiot lights and go to gages its not a plug and play deal.
