Author Topic: manual to automatic conversion  (Read 4535 times)
Offline lpapa15
  • 1979 k10 silverado
« on: August 14, 2010, 07:59:47 pm »
I own a 79 4x4 Cheyenne 3 speed manual I want to convert it to an automatic on the tree.  I have the new steering column with the shifter on the tree and a new th400.  is there any advice on the conversion?    Manual to auto...
Offline Swims350
    • Cars and trucks
Re: manual to automatic conversion
« Reply #1 on: August 14, 2010, 09:27:52 pm »
you get the column linkage for the auto? Also gonna need the correct t-case adapter to go from a th400 to your t-case. There could be a difference in case length of the transmissions too which could mean drilling new crossmember holes or driveshaft work.
www.cardomain.com/id/benwa454
« Reply #2 on: August 16, 2010, 05:37:19 pm »
You need the mount on the frame for the shift lever along with the linkages.  you will need a different driveshaft and yoke alone with moving the crossmember.
