Author Topic: Operation: Fire it up after a 2 year nap!  (Read 4248 times)
Offline Goobzilla
« on: August 15, 2010, 09:56:10 pm »
OK, so my titles aren't so catchy but I had a great day today anyway.  My 78 Stepside has been sitting for at least 2 years probably longer.  I parked it when I lived in WA and I've been back in CO over a year.  I bought a new truck in Nov '05 so the this one had gotten very little attention or driving in almost 5 years.  1st thing: Oil change, it looked pretty dirty but I can't remember the last time I had changed it.  2nd thing:  When I parked it the generic headers had melted the #5 plug wire due to very little clearance and the spark was shorting out to the header.  I replaced the wire put a straight boot on it and a boot cover, it was a tight fit but I got it in place.  3rd thing: Since the truck was so infrequently driven, I decided to go with an electric fuel pump conversion.  This should eliminate long cranking periods after months of sitting.  I mounted a Mr. Gasket 12S universal pump on the passenger side frame rail tapped a 12V key on power source and cut the existing fuel line in 2 places to tap in for the pump inlet & outlet.  Only 1 leak when I turned the key on the pressurize the system (loose hose clamp).  Once I saw the fuel filter fill up I knew we were in business.  Cranked it for a couple seconds and it fired a little rough and smoky at first but smoothed out quickly.  Forgot how well this thing ran!
Next problem:  The truck wouldn't move when put into gear.  When I get a chance next time I'll put it back up on the lift and make sure all the external linkage is good which I think it is.  Also need to check ATF level which I think (hope) might be the problem.
I'll figure out how to post a video of it running
« Last Edit: August 15, 2010, 09:59:44 pm by Goobzilla »
Offline three8six
Re: Operation: Fire it up after a 2 year nap!
« Reply #1 on: August 15, 2010, 10:33:00 pm »
Throw some lucas anti slip in there if ya really need to get it to move.
Offline Goobzilla
« Reply #2 on: September 17, 2010, 05:21:37 pm »
Boy, that tranny was REALLY low on ATF  ;D  Running and driving good now just a little brake work and I think I'll be ready for winter.
