Author Topic: identify wiring  (Read 7832 times)
Offline chronos
identify wiring
« on: August 21, 2010, 05:54:13 pm »
Does anyone know what a a 2 wire(white and orange)
wire is for?Runs under the sill and goes into the drivers pillar behind the seat.....1986
Offline nucknoel89
  • Proud to be Canadian!
Re: identify wiring
« Reply #1 on: August 21, 2010, 07:24:02 pm »
It's the interior cab light.
Offline chronos
Re: identify wiring
« Reply #2 on: August 21, 2010, 08:03:02 pm »
thats what I thought.Does it go into the
fuse box? If so how?
Offline nucknoel89
Re: identify wiring
« Reply #3 on: August 21, 2010, 08:14:59 pm »
Not sure, I'll have to take a look.  I think it's probably connected to the dimmer switch though.
Re: identify wiring
« Reply #4 on: August 22, 2010, 02:51:44 am »
I believe it goes to the fuse box. Check in the tech section of this site for the wiring diagram and trace it.
Offline chronos
Re: identify wiring
« Reply #5 on: August 22, 2010, 02:07:36 pm »
I looked at the diagrams but for me they are hard to figure out!
I don't see anywhere uder the dash or on the fusebox that where it
came from? That wire got caught up in my grinder months ago, all
that is there is the white/orange wire bare at the drivers kick panel
then going into thhe piller behind drivers side of seat.
Any pic of where it goes would ne great
Re: identify wiring
« Reply #6 on: August 22, 2010, 02:17:48 pm »
This is on my 79. It is the wire with the blue quick connector on it. The white wire splits off and heads up to the back of the instrument panel, on my truck anyways....
« Last Edit: August 23, 2010, 12:12:26 pm by beastie_3 »
Offline chronos
Re: identify wiring
« Reply #7 on: August 23, 2010, 10:59:52 am »
Thanks but pic is not working??
Re: identify wiring
« Reply #8 on: August 23, 2010, 12:12:52 pm »
OK, should work now.
Offline Altec
  • Custom De-Luxe
Re: identify wiring
« Reply #9 on: August 25, 2010, 12:19:55 pm »
Hey, I just checked my '86 after seeing your thread. Since the inside of my truck is gutted, it was fairly easy to do. The orange wire follows under the carpet, up behind the fuse box, out the top, then the orange wire goes to a battery terminal on the top left of the block. The white wire follows further up into somewhere else.
1981 K10 Short Bread - 6.5NA - SM465
Offline chronos
Re: identify wiring
« Reply #10 on: August 28, 2010, 10:01:30 am »
Thanks for the info so far , I will try to trace it now and figure it out.
That wire got caught up in my grinder months ago and got tore pretty good!
I will see if the other end is running thru the engine compartment side
Offline DnStClr
Re: identify wiring
« Reply #11 on: September 09, 2010, 05:01:08 pm »
I think you're gonna find the orange wire goes from the courtesy light socket where it tees off to the printed instrument panel circuit connector, the light switch, and to the fuse box where it picks up a b+ signal to operate the light.
The white wire goes from the courtesy light socket to the light switch.
« Last Edit: September 09, 2010, 05:35:27 pm by DnStClr »
Don
87 Chevy Silverado
