Author Topic: need help decoding engine numbers  (Read 6922 times)
Offline 84chevysilverado
« on: August 21, 2010, 06:36:09 pm »
ok so i bought this blazer the guy says its a 350 so i pulled the code on the passenger side behind the alt on the block and this is what i got 171112252 K09 13 02R I cant seem to find any codes even close enough to it or suffix codes ??? could some one help me out thanks
Offline sooner
Re: need help decoding engine numbers
« Reply #1 on: August 21, 2010, 08:07:12 pm »
The block casting number will be a maximum of 8 digits long so something is not right with your number. They can be pretty hard to read sometimes. Maybe take the wire brush to it and try again.
« Reply #2 on: August 22, 2010, 02:50:39 am »
Check behind the PS head, above the oil filter for the casting number.
Offline 75chevybakers
« Reply #4 on: September 22, 2010, 09:13:42 am »
well guys I double checked that block casting and i made a mistake its 171112252 K09 13 C2R and again thats behind the alt if that still dont sound right  il have  to try to read the code thats beside the dist. thanks marc
« Reply #5 on: September 28, 2010, 02:25:33 pm »
HELLO HELLO HELLo HELlo HEllo Hello hello anyone ?  ???
Offline ccz145a
« Reply #6 on: September 28, 2010, 04:04:45 pm »
Looks like a stamp to me, check this out http://www.348-409.com/forum/showthread.php?p=46395
ChevyMania.com says suffix code c2r is a 305
« Reply #7 on: September 28, 2010, 05:52:07 pm »
If you want to find out what kind of block it is you need to get the number off the back of the bellhousing.
K0913 C2R
K = St. Catherines, Ontario
09 = September
13 = 13th
CR2 = 1975 350 Chevelle
The other numbers are a partial VIN, which apparently won't match your truck
