Author Topic: Lost my wheel key. What can I do?  (Read 24726 times)
Offline SUX2BU99
« on: August 24, 2010, 04:56:30 pm »
 :-[   I have a set of what I believe to be McGard wheel locks on my truck. From the last time I had my rims off, I seem to have not put the wheel lock key back in it's regular spot. I have no idea where it is now and I need to know how I can get this thing off. The locks are at least 10 years old. Do wheel shops usually have a 'master' key for this kind of thing??
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: Lost my wheel key. What can I do?
« Reply #1 on: August 24, 2010, 04:58:49 pm »
You'll need the key number off your key (thats lost)   Otherwise you just have to get it off the best you can....    POSSIBLY, you could find a new set of wheel locks on the store that have a key that will fit enough to get your old locks loose.
Offline xxwckdxx
« Reply #2 on: August 24, 2010, 05:13:52 pm »
Go to a tire shop they probably can help you out, most of the time they have tons of locks laying around
74' Swb
Offline bfofish
« Reply #3 on: August 24, 2010, 06:04:39 pm »
 ;D   Go to your tool box,find the socket that will almost slip over the lock.Now pound it on,and loosen with a ratchet not an impact.Then pound the lock out of the socket and repeat.I've gotten a few parts trucks without the lock key and it hasn't failed me yet.
Offline SUX2BU99
« Reply #4 on: August 24, 2010, 06:30:58 pm »
Thanks guys. I may try the ole Vice Grip trick too since that seems the easiest. I have done the pound the socket on routine on those little bolts that hold the wheel cylinders in at the rear axle. It worked pretty well actually, after I spent enough time tapping the 1/4" ratchet to eventually unfreeze the rounded-over bolt.
« Reply #5 on: August 24, 2010, 07:20:51 pm »
Tue also make sockets that cut into the nut and let you take it off wheel. Shops also have them
Offline Swims350
    • Cars and trucks
« Reply #6 on: August 24, 2010, 08:37:27 pm »
if all else fails you're gonna need to chisel or cut them off.
www.cardomain.com/id/benwa454
« Reply #7 on: August 25, 2010, 04:32:20 pm »
Ran into this last year. There is a socket that most wheel companies have that will remove the lug.
Offline frickenbored
  • 383 Beast
« Reply #8 on: August 25, 2010, 10:18:24 pm »
We see this all the time where I work.  We have a special set of sockets that are coned inside.  You pound the cone socket on the lock and it comes right off.  We've also used an air hammer, cut a notch on one side of the nut and drive it around with the air hammer.
Offline three8six
« Reply #9 on: August 26, 2010, 12:22:40 am »
A friend of mine cut off his whole wheel...maybe not a friend more of an acquaintance. We still wont let him live it down. He cut like a pie section of the wheel off. The section with the locking lug. I just thought ya'lld get a kick out of that.
« Reply #10 on: August 26, 2010, 12:01:47 pm »
I recall a video or pics of two kids doing something similar on their rice burner.
« Reply #11 on: August 26, 2010, 12:23:30 pm »
Offline SUX2BU99
« Reply #12 on: August 26, 2010, 05:54:57 pm »
Are you meaning this is something that can be bought at a retail store? Rather than taking the time to go to a tire shop?
« Reply #13 on: August 26, 2010, 06:10:19 pm »
Yup thats what I was thinking of Irish.
Offline low budget
« Reply #14 on: August 26, 2010, 06:10:45 pm »
This is what the tire shop had to do to my van, key was striped.  Came off quicker than a whistle!!! ;)
