Author Topic: shackle flip  (Read 14502 times)
Offline chadbice
shackle flip
« on: September 02, 2010, 10:05:26 am »
I have an 84 silverado,  w/ 4" lift was wondering if the shackle flip from ORD is worth it.   I like the idea of removing the lift blocks.  And does it give you a little more axle twist.
Offline 4x4orbust
Re: shackle flip
« Reply #1 on: September 02, 2010, 03:28:14 pm »
i think the shackle flips are def. worth it.   easy way to get rid of blocks, and will yield a little more flex.   if by "twist the axle" you mean change the pinion angle, yes, they do.   but with a 4" lift, it kinda corrects the angle more than hurts it.
Offline Altec
  • Custom De-Luxe
Re: shackle flip
« Reply #2 on: September 02, 2010, 03:55:14 pm »
Shackle Flip for sure! But I suggest DIY4X. Their kit allows you to ditch the junky factory shackles.
http://diy4x.com/cart/index.php?route=product/product&path=24&product_id=125
1981 K10 Short Bread - 6.5NA - SM465
Offline 76 k10
Re: shackle flip
« Reply #3 on: September 02, 2010, 09:15:51 pm »
you no you can do a do it yourself rear shackle flip.
Offline chadbice
Re: shackle flip
« Reply #4 on: September 03, 2010, 03:44:22 am »
thank you for the info.
Offline team39763
Re: shackle flip
« Reply #5 on: September 05, 2010, 10:09:59 pm »
I think Lorne(HaulinIt) did a DIY shackle flip on his truck.  Might want to search some of his old posts for pics and info.
Offline 4x4orbust
Re: shackle flip
« Reply #6 on: September 06, 2010, 07:57:41 am »
i have heard of people using the rear axle's front spring hanger as a home made shackle flip.   i have heard it works great and costs very little to do.
Offline malibu795
Re: shackle flip
« Reply #7 on: September 06, 2010, 01:25:41 pm »
i used ORD shackle flip on mine..
got some 3* shim to rotate the pinion back down i can take better picturs if needed..
also the cross over steering is pretty much a must do
thread of me doing it.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=16249.msg127561#msg127561
adam wildman
75 K25 383/400
Re: shackle flip
« Reply #8 on: September 10, 2010, 05:28:35 pm »
To make your own, use the FRONT spring perch on a 4x2 truck.
