Author Topic: vacuum advance question  (Read 15506 times)
Offline txchainsawgogi
« on: September 02, 2010, 10:43:54 am »
What would cause the engine to run roughly with the vacuum lines connected, specifically to the advance on the distributor.
If I cap off the vacuum advance it starts and idles and runs much smoother.
Offline Grim 82
Re: vacuum advance question
« Reply #1 on: September 02, 2010, 11:48:41 am »
Sounds like you are using manifold vacuum. You could switch to a timed vacuum source.
Offline jaredts
« Reply #2 on: September 02, 2010, 07:30:45 pm »
Where is your timing set, or has it been set?  Timed vacuum might help or retard your timing and leave the vacuum alone.
« Reply #3 on: September 02, 2010, 10:37:06 pm »
I haven't set the timing yet... it was doing the same thing with the old distributor. I figured a new one would help, and it did with everything but the vacuum advance.
Offline jaredts
« Reply #4 on: September 03, 2010, 06:31:33 am »
I think you need to set your timing before you try to troubleshoot any further, but if you just wanted to play around you could try to retard your timing a little and see if it makes it run as well as it does with the vacuum unhooked.
« Reply #5 on: September 03, 2010, 11:26:49 am »
I've never timed a truck before...only a few motorcycles. I'm sure I could do it though...
Offline Grim 82
« Reply #6 on: September 03, 2010, 11:33:28 am »
Nothing to it. Do you have a timing light? Make sure to plug the vac advance hose when you do it.
« Reply #7 on: September 03, 2010, 06:45:06 pm »
Id have to borrow one from autozone or some place. My haynes manual mentions a VECI label with tune up specs that's long gone from the engine compartment.
What do I do?
« Last Edit: September 03, 2010, 07:01:26 pm by txchainsawgogi »
Offline Grim 82
« Reply #8 on: September 03, 2010, 09:51:05 pm »
The VECI label will give you the factory spec timing baseline,  but I would ignore that and set it between 8-12 degrees before TDC. Most labels will say 4 or 6 degrees BTCD. I run mine at 12 BTDC without EGR. If you can get a dial-back timing light and set your total advance and work your way back to initial timing that would be prime.
Offline 454ss
  • I WANNA RACE IN A BIGFOOT TRUCK!
« Reply #9 on: September 03, 2010, 09:58:07 pm »
What do I do?
I've got a timing light (well, 2) and can help if you want, possibly this weekend. :)
Jay
Searching for my ideal 1973-87 fullsize.
1982 C10 Custom Deluxe stepside - traded
1977 C10 Custom Deluxe longbed - junked
Current:
1991 Chevy S10 Blazer 4x4
1995 Olds Silhouette
2009 Chihuahua
« Reply #10 on: September 09, 2010, 04:22:05 pm »
Dang, can't seem to find anyone that loans timing lights. Kind of lame. 454 id take you up on that but my truck isn't street legal(or even in my name yet) and another ticket is the last thing I need.
Offline 454ss
« Reply #11 on: September 09, 2010, 06:38:07 pm »
Well, where are you? I don't mind taking a drive.  8)
Jay
Current:
2009 Chihuahua
« Reply #12 on: September 10, 2010, 12:05:40 am »
I think O rileys/kragens does.
« Reply #13 on: September 10, 2010, 12:06:17 am »
No harm in buying one, too. Good investment IMO.
« Reply #14 on: September 10, 2010, 01:40:10 am »
   Have you checked your vacuum advance on your dist. yet to see if it was operating properly ?  Check the most obvious first is my theory.
