Engine/Drivetrain
sporadic misfire
Topic: sporadic misfire (Read 15788 times)
greenmonster
sporadic misfire
September 06, 2010, 09:12:38 am »
I have a misfire that I can't track down.It is from idle-2500.It makes a puffing sound from both sides of the exhaust.It feels like a dead cylinder,but it moves around.I put a vacuum gauge on it and it is steady at about 20in.Any ideas would help.
Re: sporadic misfire
September 06, 2010, 09:47:36 am »
True duals
greenmonster
September 06, 2010, 09:52:12 am »
Yes,true duals.
Laderhosen
September 06, 2010, 10:12:39 am »
Are your header bolts tight??
'82 3/4 ton, 350, th400,
'88 K5 Blazer, 350, 700R4
’98 BMW 328i daily drive
greenmonster
September 06, 2010, 10:17:34 am »
Yes they are tight.I just switched headers 2 weeks ago,but I have had the problem for months.
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
September 06, 2010, 12:48:37 pm »
common diagnoses tried yet? wires, plugs, cap, rotor? Got a temp gun? point it to each cyclinder at header and see if one reads much lower. These temp guns (usually w/ a red laser) are very cheap. I use it for a lot of things.
At night, no light, idling, pop hood, any sparks from wires?
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
greenmonster
September 06, 2010, 01:20:35 pm »
I put a full tuneup on it,and it didn't help.I even tried a different distributor that a friend had.
1980c10
September 06, 2010, 04:08:14 pm »
Try a compression test.
btw sgt
"At night, no light, idling, pop hood, any sparks from wires?"
I did this and my wires were glowing blue.
greenmonster
September 06, 2010, 05:07:43 pm »
I done a compression test 2 months ago,and it was fine.
topp
September 07, 2010, 12:10:34 pm »
If the symptom wasn't there 2 months ago, the test would be good......
If this started since then, the test is needed
'90 Suburban TBI 350
greenmonster
September 08, 2010, 11:03:05 am »
It's been like this for 6 months.It was running great,then one morning it started acting this way.
TexasRed
September 08, 2010, 01:31:02 pm »
Fuel filter good?
greenmonster
Reply #12 on:
September 08, 2010, 02:23:22 pm »
I replaced that too.I pulled a plug and grounded it out and the spark is orange.Is that normal for hei.
Reply #13 on:
September 08, 2010, 10:52:03 pm »
It should be blue. Where did you ground it to?
TexasRed
Reply #14 on:
September 08, 2010, 11:07:48 pm »
You have 12 volts going to the distributor?
Engine/Drivetrain
sporadic misfire
