Author Topic: What will a 8 lug center hub fit?  (Read 4626 times)
Offline 82gmc3/4ton
« on: September 06, 2010, 05:32:34 pm »
It's from a 3/4 ton 10 bolt GM front axle. Will it also fit the Dana 44 or other Danas, Ford, Dodge, and or Jeep? I was wondering because of the similar bolt patterns for the rotors/wheels.
Re: What will a 8 lug center hub fit?
« Reply #1 on: September 06, 2010, 09:28:37 pm »
Don't think so. The 10 bolt axle shaft is smaller and wont lock up in the dif. So that being said I highly doubt the hubs will switch out without any other mods
« Reply #2 on: September 06, 2010, 10:15:48 pm »
It will fit a Dana 44. Keep in mind there is two different spindle lengths. Thinking the 44s is just a tad shorter than the 10 bolts. As long as you have the spindle from the 10 bolt you will be all set. As far as the axles go the stub shaft is the same for a 10 bolt or a 44. The difference in length of the spindle isn't enough affect them. If you use the longer spindle with the hub from the shorter one you won't be able to get the wheel bearings tight enough. The opposite way you can't start the hub lock nuts. As far as other axles. I sold a complete set of spindles, 8 lug hubs, rotors, backing plates, calipers etc. from a 10 bolt. He installed it all on a Dana 44 that he said came out of a late 70's F150, and he had it under his CJ7. He had put a Dana 70 under the back and wanted to upgrade the front to 8 lug as well.
