Author Topic: Rear axle swap?  (Read 5066 times)
Offline Gearhead1
  • Its not much, but its all I've got
Rear axle swap?
« on: September 08, 2010, 09:25:35 am »
Hey everyone, I have a 10 bolt posi for my 87 R10 that needs a complete rebuild (brakes included). I['m considering a swap to another axle entirely if I can find one in good condition.
Can anyone suggest a better alternative? I'd like to upgrade to rear discs as well and I'm wondering if a later model trucks may have come with a better set-up? I'd like to build it to handle an eventual 400hp - 450ft/lb engine upgrade
Re: Rear axle swap?
« Reply #1 on: September 09, 2010, 01:35:53 am »
Someone makes a disc brake kit for it. I think it uses newer GM parts.
Offline Gearhead1
Re: Rear axle swap?
« Reply #2 on: September 09, 2010, 09:34:05 am »
Thanks.
I did see a cool thread here on a disc brake conversion. I was hoping there might be another GM product  that had the same width axles that might work so I didnt have to do so much work. (wondering about newer trucks, vans or Impala/caprice's etc
Re: Rear axle swap?
« Reply #3 on: September 09, 2010, 10:47:17 am »
You can search eBay for it that's were I found mine for my 14 bolt
Offline ohio hab
  • 1984 C-10, 383 SBC
Re: Rear axle swap?
« Reply #4 on: September 10, 2010, 06:33:48 pm »
I would just rebuild your Ten Bolt rearend, If it is a 8.5 Ten Bolt. I have an 8.5 Ten Bolt with an Eaton Posi  Unit, Moser Axles, Richmond 3.73 Gear pushing a built small block around 375 H.P. The person who built my axle assembly said this axle assembly is good for up to 550 H.P. It's much easier to work with what you have, Go Spitfires.
Offline Gearhead1
Re: Rear axle swap?
« Reply #5 on: September 13, 2010, 07:35:31 am »
Thanks!
