Author Topic: front swaybar  (Read 6739 times)
Offline john
front swaybar
« on: September 11, 2010, 09:16:59 pm »
i need help with how to install bushings for front swaybar i have bought 2 sets neither set will fit
 does anybody know of a special tool for pressing them in
                                       86 k 20 4x4
Offline Prong
Re: front swaybar
« Reply #1 on: September 13, 2010, 02:59:09 am »
If you're talking about the eye bushings that bolt to the spring plates, Mr. Hotwrench (aka torch) is your friend. Do it outside because that smell stinks to high h**l.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Offline Da67goatman
  • Burban
Re: front swaybar
« Reply #2 on: September 13, 2010, 08:46:18 am »
The poly ones I used went in from each side in 2 pieces then slide the metal roll pin lookin thing through.
<Pitcrew>
Offline john
Re: front swaybar
« Reply #3 on: September 13, 2010, 02:34:19 pm »
don't think i want to melt them in but thanks, could you tell me where you got the two part bushings at what brand ?
                               thinks for the info guys
Offline Da67goatman
  • Burban
Re: front swaybar
« Reply #4 on: September 13, 2010, 07:14:00 pm »
I bought Energy suspension bushings from Summit.  Depending on what size bar you have should be from 20-45 bucks for all the bushings the end ones and the frame mounts.  Energy suspension has a pretty decent website for looking up part numbers then I just put the number into a summit search and presto exactly what i need, no run around.
<Pitcrew>
Offline john
Re: front swaybar
« Reply #5 on: September 13, 2010, 08:29:42 pm »
thanks for the help
Offline Prong
Re: front swaybar
« Reply #6 on: September 14, 2010, 05:19:07 pm »
Thought you were talking about removing the old ones. Anyway, the new ones are 2 piece as stated above. Wire wheel the insides out to remove any rust and burrs, then lube it up and go to town. I've found the easiest way is to install the sleeve into one of the halves then install it into the sway bar. Then lube the other half and with persuasion the other half will go right in.
Offline Da67goatman
  • Burban
Re: front swaybar
« Reply #7 on: September 14, 2010, 05:40:15 pm »
I used a vice to clamp them together when I did mine.
<Pitcrew>
