Author Topic: TRUCK DRIVES CROOKED  (Read 6723 times)
Offline valley 84
« on: September 17, 2010, 10:23:12 pm »
I HAVE A 84 CHEVY STEPSIDE SHORTBED 2WD I HAVE IT DROPPED IN THE FRONT WITH DROP COILS AND THE REAR LEAF SPRING FLIPPED SO THE PROBLEM IS THAT FROM THE REAR IT LOOKS LIKE ITS DRIVING CROOKED...BED DRIFTS TO RIGHT THAN STR8ENS OUT IM ON STOCK 15'S DOES ANY ONE KNOW WHAT THE DEAL IS???THANKS FOR THE INFO... ??? :-[
Offline Grim 82
Re: TRUCK DRIVES CROOKED
« Reply #1 on: September 17, 2010, 10:30:00 pm »
When you flipped the rear leafs how did you get them to align with the perches? It sounds like your axle is skewed, and your CAPS LOCK BUTTON IS STUCK. Welcome to the site. Post up a pic of your rear springs/axle and somebody can probably help you figure it out.
Offline rwhit57
« Reply #2 on: September 17, 2010, 10:45:31 pm »
Take some measurements, center of hub front to rear both sides see if they're the same. Sounds like the rearend is not in the alignment holes.  Was it ok before you flipped the rearend?
Randy from Okla
Whoever said "Money can't buy happiness" has obviously never seen a speed shop!
Offline valley 84
« Reply #3 on: September 17, 2010, 11:27:56 pm »
THANKS FOR THE PROMPT RESPONSE ILL USE THE TIPS AND POST THE RESULTS....THIS WEBSITE ANSWERS FAST IMPRESSIVE WORK GUYS!! ;D ;D ;)
« Reply #4 on: September 18, 2010, 12:35:04 am »
I think his doomed he button must be stuck all the time  :'(
« Reply #5 on: September 18, 2010, 11:44:00 am »
Turn you caps lock off.
If it wasn't crooked before, make sure you put the spring perches on correctly.
