4 Wheel Drives
Fitting a front propshaft
Topic: Fitting a front propshaft (Read 22773 times)
Re: Fitting a front propshaft
Reply #15 on:
October 18, 2010, 09:52:07 pm »
You need to rotate the carrier so we can actually see inside the differential.
Gov loc
Open differential
fitz
Reply #16 on:
October 18, 2010, 10:56:20 pm »
Just look for broken parts, if you have some, it's a Gov Lock.
screamin86
Reply #17 on:
October 18, 2010, 11:28:14 pm »
Hahahahahaha true true!
86 ta:lm7 hot cam boltons
Reply #18 on:
October 18, 2010, 11:46:56 pm »
Nothing wrong with the gov loc for normal use. If you want performance or heavy duty use - it's a grenade.
screamin86
Reply #19 on:
October 18, 2010, 11:58:28 pm »
I agree! I killed the one in my yukon last fall.
Laderhosen
Reply #20 on:
October 19, 2010, 06:06:17 am »
Quote from: Irish_Alley on October 18, 2010, 08:09:02 pm
You can have posi on the gravel and on pavement only one wheel
Ok, under what conditions does it lock up???
Thanks for the pics Vile, I just WISH I’d either taken more photos, or rotated the axle. It was getting dark when I took the pics, and wanted to finish the job off, plus I was annoyed and wanted to get the job done as I’d spilt diff oil all over my drive after knocking the oil pan.
Last Edit: October 19, 2010, 06:09:19 am by Laderhosen
'82 3/4 ton, 350, th400,
'88 K5 Blazer, 350, 700R4
’98 BMW 328i daily drive
Reply #21 on:
October 19, 2010, 08:00:26 am »
I was saying an open can do that
Laderhosen
Reply #22 on:
October 19, 2010, 12:41:39 pm »
Quote from: Irish_Alley on October 19, 2010, 08:00:26 am
Gotcha...
Reply #23 on:
October 23, 2010, 11:37:11 am »
rotating inertial locks a gov-loc. It is great for slip on wet boat lauches, mud traction and ice as it was designed for.
It was NOT designed for neutral drops or drat racing.
Laderhosen
Reply #24 on:
November 30, 2010, 10:57:20 am »
What about snow
: (click on the image below, should bring up a video....)
Last Edit: November 30, 2010, 11:04:44 am by Laderhosen
4 Wheel Drives
