Author Topic: Which motor would you use?  (Read 14866 times)
Offline fitz
« on: September 18, 2010, 02:34:49 pm »
Now that summers over it's time to think about replacing the junk SB 400 TPI motor in my truck.
I've narrowed it to 2 choices (although I'm always open for suggestions).
#1 Would be a 454 BB TBI motor converted over to a 4 barrel. It's a used motor but it runs great. I would detail the motor,all new gaskets and timing chain, and maybe a edelbrock torquer cam/manifold/carb package.
#2 Would be a new GM Goodwrench 350 and keep the TPI set up.
I know neither of these are going to make killer HP, but if goes as good as it did with the SB 400 I will be happy.
Offline Swims350
    • Cars and trucks
Re: Which motor would you use?
« Reply #1 on: September 18, 2010, 04:17:04 pm »
might want the big block then. I'd think the 350 would make less power the the 400 tpi and the 454 might make close to it if not maybe more and should be more torque. I'd use big block, I don't like computer controlled stuff and I'd just like to have a big block.
www.cardomain.com/id/benwa454
« Reply #2 on: September 18, 2010, 05:24:29 pm »
Depends on if you have all the right brackets and exhaust for the big block.  Hope gas don't go back to $4/gal again.  The 350 would be my choice because of the ease... My $.02
Offline Grim 82
« Reply #3 on: September 18, 2010, 09:00:33 pm »
This is going in your blue stepside?         Big Block.
Zieg has a good point about having the right stuff to make the swap easier, but if you aleady have the 454 you might already have most of what you need, or could get it for less than a new Goodwrench 350 would cost.  Unless you do some building and bolt-ons with the 350 I doubt that you'll make the power that you were used to with the 400.
Offline fitz
« Reply #4 on: September 18, 2010, 09:40:54 pm »
 Yes, it's for the blue stepside.
 I figure money wise it will be about the same.
The Goodwrench motor is around $1900. I figure if I go with the 454 by the time I get headers, matching cam/manifold/carb, modify the exhaust, and get new sheetmetal for the motor it will be well over $1000 (and we all know how those estimates work out).
 I figure the Big Block is mild enough that the turbo 350 will hold up.
Offline mountaindrew
    • Picasa truck album
« Reply #5 on: September 19, 2010, 09:26:57 am »
I love a big block in anything you can squeeze one in.  BUT...for ease of swap, 350, not to mention gas mileage and longevity of your th350.
1986 Chevrolet C20 Silverado, C6P, 454, TH400, 3.73, FF
oil and trans cooler, 6 qt oil pan, p/w, p/l, air, cruise
17" Dodge wheels & E rated Michelins, Curtis hitch, Prodigy, Equal-i-zer
Offline fitz
« Reply #6 on: September 19, 2010, 09:51:05 am »
The gas mileage does not bother me but I am a little concerned about the turbo 350. I was thinking that it would hold up behind a mild big block. It's a fresh tranny, the 205 has been gone through, and the truck has had new driveshafts made for the 6" lift. Not sure if I want to change all of this stuff out,
Offline Psycho71
« Reply #7 on: September 19, 2010, 12:44:02 pm »
For fuel mileage and expediency, the small block would be the way to go.
For low end (usable) torque, nothing beats the cubic inches.
Offline 76 k10
« Reply #8 on: September 23, 2010, 02:47:09 am »
350 with a big cam headers intake and msd will do you good.
Offline fitz
« Reply #9 on: September 23, 2010, 03:10:53 pm »
I already have 1 of those waiting to go in my camaro. That "big cam" may not do to good in the truck towing a car trailer.
Offline 76 k10
« Reply #10 on: September 24, 2010, 04:10:10 am »
i ran a 1959 283 with a comp cams 292h in it and it would tow 12.000 pounds with no big problems. just run a stall
Offline novamike66
« Reply #11 on: October 02, 2010, 08:37:07 pm »
Why not just rebuild your 400?
If your 400 hasn't already been bored, I'll sure will take it off your hands.
« Last Edit: October 02, 2010, 08:41:18 pm by novamike66 »
Offline TexasRed
« Reply #12 on: October 02, 2010, 08:42:31 pm »
I think a rod exited the 400 block while the engine was running.
Offline Layne
« Reply #13 on: October 02, 2010, 08:52:29 pm »
Na it'll be okay running on 7 cyl.  Techincally it's a 350 now...
Offline fitz
« Reply #14 on: October 02, 2010, 11:25:48 pm »
I'm guessing my block is junk.
