Author Topic: transmission cooler lines  (Read 11598 times)
Offline seventyx3
« on: September 20, 2010, 10:08:56 pm »
I bought a pair of transmission cooler lines from Classic Tube for my 73 online.  They listed them as OE fit for 71-75 which I thought was weird but I got them anyway.  They didn't fit.  No amount of tweaking was going to make it work.  I have the originals and I'm sure they're are the stock lines.  I will have to pay shipping to send them back.  Long story, short; Try someone other than Classic Tube. >:(
Re: transmission cooler lines
« Reply #1 on: September 23, 2010, 03:17:59 pm »
I have had great luck with Classic Tube.  Got a side by side comparison of the new vs old.
Offline fitz
« Reply #2 on: September 23, 2010, 10:47:07 pm »
My truck has tranny lines from Classic Tube and they fit like a glove.
Seems odd that yours are listed for a 71-75.
Offline seventyx3
« Reply #3 on: September 25, 2010, 04:31:30 pm »
Can someone post a pic of tranny line routing please?  These lines are definitely different side by side.  The product sticker says 71-75 1/2 ton th350 2wd line.  CTT1002SC  They are supposed to be direct fit prebent lines.  In 73 they ran next to the engine oil pan in a factory clamp.  I'm wondering if these are really for a 67-72 pickup.
Offline 74chev4x4
« Reply #4 on: September 26, 2010, 09:57:05 am »
Do you need to specify what trans they are going to turbo 350 or turbo 400 or do both hook up in about the same spot on the two trans, just a thought.
« Reply #5 on: September 26, 2010, 10:26:54 am »
They are different between th 350 and 400 and 2wd or 4wd
Offline 69byrd
  • Haulin!
« Reply #6 on: September 26, 2010, 10:36:20 am »
I have their trans lines on my truck and they fit great!
Offline seventyx3
« Reply #7 on: September 27, 2010, 11:03:46 pm »
http://www.classictube.com/store/index.cfm?fuseaction=product.display&product_ID=110431
They list them the same for th350 and th400 2wd.  I'm glad you've had good luck with them, but they're listed as 71-75 and mine don't fit.  Now I'll have to pay for shipping to fix their mistake and hope they send the correct lines.   Inline was more expensive but they list theirs as 73-80.  Anyway, buyer beware.
Offline billwater24
« Reply #8 on: December 18, 2010, 11:20:44 pm »
A bit late now, but NAPA sells poly brake line you can bend easily with your hands.  You can get a couple of 5' lengths and route your own.  I just finished doing this myself.  As long as you don't have a show truck, function is the key!  Remember top of transmission to top of radiator, bottom to bottom.
1976 K20 Plow Truck 350/350 NP205
1975 K10 Parts Donor
Offline Wardog
« Reply #9 on: December 19, 2010, 06:42:24 pm »
I have used classic tube several times-for my 69 Camaro, 75 K10, 75 K5 78 K5.  The only issue was with the 78, one line was way jacked up, clearly bends in wrong place.
