Body, Glass & Paint
needing help
Topic: needing help (Read 5799 times)
raelayotte
needing help
September 22, 2010, 08:17:18 am »
just above the doors. what are they called. i would like to remove. them if i can. this is for a 87 k5 blazer
jaredts
Re: needing help
September 22, 2010, 08:42:18 am »
I think they are called gutters. You can remove them but they are screwed on and it would be best to weld the holes shut.
thachevythang
Re: needing help
September 23, 2010, 09:23:08 am »
I'm not sure of the technical name but when I replaced mine the order stated cab trim. Which I know is the moldings underneath the rear window and around to the bottoms of what your talking about. Mine were bolted in and easy to remove. It helps if you can get the chrome trim off first but youre probly going to scrap them anyways so its still easy to remove them with the trim on.
'85 SHORTBED
Grim 82
Re: needing help
September 23, 2010, 09:35:54 am »
Gutters, aka drip rail moulding. There is half a dozen or so hex head screws that hold each one on, but like jared said, if you remove them, seal up the holes.
78 Chevyrado
Z62 ON-ROAD
Site Supporters
Re: needing help
September 23, 2010, 11:12:12 am »
^ Yep Drip Rail Mouldings.
The chrome part just snaps on the back part. Pry the crome off from the bottom side and then you can use a ratchet or nut driver to remove the bolts. If you dont want to do that, a combo wrench will get them off just as good but a little slower.
Re: needing help
September 23, 2010, 02:19:12 pm »
They are welded to the roof on Blazers.
Bitzer!
Smiles per gallon
Re: needing help
September 23, 2010, 04:28:00 pm »
Quote from: Captkaos on September 23, 2010, 02:19:12 pm
cut, grind, filler, smooth, paint
1979 GMC CrewCab C20 1t
raelayotte
Re: needing help
October 01, 2010, 10:31:47 am »
thanks guys im not on much so i will take picks of the prosess
Body, Glass & Paint
needing help
