Author Topic: REAR END SWAP  (Read 9754 times)
Offline Monkeyman73
REAR END SWAP
« on: September 24, 2010, 01:24:23 am »
My rear diff is going out and i would like to replace it  but would like to change it with one  that has higher gears that would alow me to have better freeway speed.
What can i use with a 3 speed tranny, or also was thinking of going with the 4 speed, what can work with this set up?
Re: REAR END SWAP
« Reply #1 on: September 24, 2010, 05:44:17 am »
What are your current gears?
Offline Monkeyman73
Re: REAR END SWAP
« Reply #2 on: September 24, 2010, 08:00:25 pm »
Don't know , I have a 3 speed Saginaw trans and to me it looks like the origanal rear diff. its a 1973 chevy custom.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: REAR END SWAP
« Reply #3 on: September 24, 2010, 09:00:03 pm »
without knowing, you may swap rear ratios with the same ratio.  ???
Offline Monkeyman73
Re: REAR END SWAP
« Reply #4 on: September 24, 2010, 10:56:37 pm »
Got it ,, thanks ill investigate what diff i have.
Re: REAR END SWAP
« Reply #5 on: September 25, 2010, 07:41:02 am »
If the tag is still there it should be on it. If not pop the cover off and count the teeth on the ring and the pinion.
Offline Monkeyman73
Re: REAR END SWAP
« Reply #6 on: September 27, 2010, 02:52:15 am »
will do thanks
