Author Topic: Transmission Swap - TH350 to 700R4  (Read 4227 times)
Offline RivMan
« on: October 02, 2010, 11:24:29 am »
Hey guys, I'm looking at swapping the trans in my truck, and I'm wondering what else will have to be swapped out. Will the transfer case (NP203) bolt up? Will I need new drive shafts? Cross member? Anything I'm not thinking about?
1976 K10
350
TH350
NP203 Part Time converted
D44 / 12 Bolt (3.73's)
33" tires
Thanks
-Rob
« Last Edit: October 02, 2010, 11:26:08 am by RivMan »
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Transmission Swap - TH350 to 700R4
« Reply #1 on: October 02, 2010, 11:46:25 am »
this question gets asked every few months.  Use the search engine on this site and type in some key words, you should be able to read past histories from others who have done this common transition.  The crossmember will need to be moved back, driveshaft size adjustment will most likely be needed.
« Last Edit: October 02, 2010, 11:49:48 am by SgtDel »
Offline RivMan
« Reply #2 on: October 04, 2010, 07:51:14 am »
I tried the search, and I can't seem to find much on the 4x4's, seems mostly a 2wd thing. I'm mainly worried about the transfer case bolting up.
Thanks
-Rob
Offline Grim 82
« Reply #3 on: October 04, 2010, 09:34:46 am »
I think you will need a different output shaft on the trans to use the TH350 to 203 adapter.
Without turning this into a 203 vs 208 thread, I will say that the cheapest and easiest route would be to find a donor truck with a 700r4/np208 combo and take the whole works.
