Author Topic: 1981 c10 p/s gear box rebuild???  (Read 6805 times)
Offline Fudd
« on: October 06, 2010, 03:16:04 pm »
I was just wondering if any one has done it or is it easier to just replace it.
mine works fine it just leaks like crazy.
Re: 1981 c10 p/s gear box rebuild???
« Reply #1 on: October 06, 2010, 03:26:29 pm »
If it is leaking down low replace the seal if there is no side to side play in the box.  You should be able to borrow the pitman arm puller through loan a tool at Autozone.  It is a fairly easy job to do.
Offline Fudd
« Reply #2 on: October 06, 2010, 04:19:10 pm »
haven't really noticed any play in it...I'll check it out tonight.
Thanks!!
« Reply #3 on: October 06, 2010, 05:09:48 pm »
Get someone to lightly turn the wheel back and forth, that will tell you.  You may have a high pressure hose leaking and not the box.  Either fix is fairly easy.  Good Luck
Offline jaredts
« Reply #4 on: October 06, 2010, 07:51:01 pm »
If its the lower seal you can just replace it--its not super easy but not terrible.  If you have the money I'd be tempted to buy a new box as I've had bad luck with them still leaking a little after replacing it.  I assume because of wear that causes the shaft to eat up the seal.  I've really only had one experience with this though so I could be wrong.
Offline Fudd
« Reply #5 on: October 07, 2010, 08:20:31 am »
checked it out last night...its leaking all over and has a lot of play in it so i think I'll go ahead and replace it.
thanks for the info folks.
