Author Topic: 78 GMC sierra classic-Radio and Heater fan stay on after key is off  (Read 7288 times)
Offline chev2low63
  • the steez
First post... My 78 GMC Radio and heater fan stay on after the key is off. If I disconnect the battery and then reconnect, it doesnt come back on. Ignition switch??? any help would be very appreciated!! thanks
Re: 78 GMC sierra classic-Radio and Heater fan stay on after key is off
« Reply #1 on: October 08, 2010, 08:26:56 pm »
First time I heard of this but like you said the only thing that I think it could be is the switch
Offline chev2low63
  • the steez
« Reply #2 on: October 08, 2010, 08:33:07 pm »
thanks irish, im just gonna keep fishin around for a while. maybe its something stupid easy! ???
« Reply #3 on: October 08, 2010, 08:59:50 pm »
I had a 66 Chevy on a 70's chassis with a mix breed of 66 and 70's wiring. Had a kill switch, and a momentary push button switch to start it. The truck would shut off fine unless the wipers were on, then it would stay running until you shut them off!
Offline chev2low63
  • the steez
« Reply #4 on: October 08, 2010, 10:08:57 pm »
one more thing to add:The light on the radio always comes on when the truck is on,  no matter if the radio is on or off. When I reconnect the battery and start the truck, if I dont turn the radio or the heater on it will go off when i turn the truck off. just brainstorming. thanks!
« Reply #5 on: October 09, 2010, 07:45:37 am »
Sounds like a back feed from something being added.  What after-market stuff has been added?
Offline chev2low63
  • the steez
« Reply #6 on: October 09, 2010, 08:46:43 am »
There is a CD player is and there is an amp, those are the only aftermarket electronics. All I did was replace another deck and amp that was already in the truck.
« Reply #7 on: October 09, 2010, 10:09:41 am »
Unhook the radio, does the heater fan stay on after the key is off?
Offline chev2low63
  • the steez
« Reply #8 on: October 23, 2010, 04:01:40 pm »
the heater fan does stay on when the radio is unhooked. I also disconnected the heater fan and kept the radio powered and it still stays on. Another thing thats strange is when the truck is off the radio and heater are going if I hit the power window switch and hold it the radio will go off but when I let up on the switch it comes back on. Think im just gonna replace the ignition switch for starts. thanks everyone for helping!!
Offline chev2low63
  • the steez
« Reply #9 on: October 26, 2010, 07:00:43 pm »
replaced ignition switch and its doing the same thing.
« Reply #10 on: October 26, 2010, 08:26:02 pm »
How does your junction box look under the hood
Offline 75blazer
« Reply #11 on: October 27, 2010, 12:03:45 am »
happened to me recently. problem fixed itself but i learned it can be a couple things. 1. the ignition switch at the bottom on the steering column is loose or broken. 2. the rod inside the steering column can be out of adjustment (not likely).
« Last Edit: October 27, 2010, 12:16:25 am by 75blazer »
