Author Topic: Vacuum help  (Read 3044 times)
Offline cormay1230
Vacuum help
« on: October 11, 2010, 10:25:43 pm »
I have a 1977 siverado with the 350, 4bbl quadrajet. I was relpacing valve cover gaskets today and had to remove some vacuum hoses. After replacing the passenger side I have mixed up the vacuum lines. can anyone help by telling me which ones go where.(including the ones coming from air cleaner)  Thanks to all for your help
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Vacuum help
« Reply #1 on: October 12, 2010, 07:46:26 am »
you should have a silver sticker label on the radiator support by hood latch showing vacuum diagram.
This is from my '79, which should be similar to your '77....
www.delbridge.net/vacuum.html
Offline cormay1230
Re: Vacuum help
« Reply #2 on: October 12, 2010, 05:10:04 pm »
I have the sticker, but it has fadded and can no longer be read. Thanks for the pics I will see if i can match any with what I have. Do you know where the two coming off of air cleaner goes? I think that will help me narrow it down alot. Thanks Again!
