Author Topic: how do I drain the tranny  (Read 3350 times)
Offline Buddy
« on: October 12, 2010, 07:26:35 pm »
I have a 700r tranny that I over filled, cant seem to find a drain plug do I have to remove the entire pan
Offline jaredts
Re: how do I drain the tranny
« Reply #1 on: October 12, 2010, 07:29:06 pm »
There's something like a siphoning hose with a bulb type hand pump on it--real cheap setup.  A couple of bucks and a couple of minutes.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: October 12, 2010, 07:43:09 pm »
unhook one of the lines at the radiator and run the engine for about 4 seconds.   Make sure you have a jar or something with a rag to catch the fluid or you will have a mess.  I think the bottom line will pump out and the top line is return, so keep that in mind when placing the jar.
make sure you don't run it more than 3 or 4 seconds, you don't want to mess up the pump.  If you need to drain more, run the engine normally first for a bit so not to run your trans pump dry.
« Reply #3 on: October 12, 2010, 07:44:11 pm »
Some don't have a bolt to frail them. Think you can get some put by removing the drive shaft yoke also
