Author Topic: 86 GMC 2wd 3spd 350: So after new heads, plugs & wires, I consisently get 12 mpg  (Read 4315 times)
Offline lbrowne
Is that a little low? I have 3.73 gears, truck has 119k miles.
My daily commute, and yes I drive it daily since I'm inbetween cars right now, it's partial highway but can get congested and then suburban neighborhood drive home. but not a huge lot of stop n go traffic. On the highway it can slow to about 35-40, then get back up to 60 again.
On the highway I do about 60-65, all other times it's about 35-45. I've eliminated my heavier foot, and I consistently get 12.xx mpg. (over the last 8 tanks since I started monitoring it)
I'm going to check the timing soon as I can get my hands on a timing light (I can't understand how I don't have one yet lol)
Earlier the summer we installed a set of professionally rebuilt heads (stock spec, no more blue smoke yay), she has new plugs and wires, good air filter.
I'm thinking maybe a vacuum leak too? That would affect gas mileage wouldn't it?
1986 GMC Sierra Classic
My first truck! (completely stock...for now)
For the specs you provided, 12.x is respectable, What size tires?  Is the speedo/odo accurate?
Offline lbrowne
You know what, I was just coming back to post that I'm running 31x10.50 tires. I know those are affecting it as well, but I had them put on not long after I first got the truck last year so I have no benchmark.
If you keep the speed below 60 you will see the mpgs go up one or two my 86 with a th350 and some other 350 would get 12-14 depended on how I drove it and where I got gas. If I got it from the cheapest place then it would be lower but if I spend more if would go up driving it the same way and all.
