Author Topic: Rubber or Cork valve cover gaskets?  (Read 12877 times)
Offline lbrowne
« on: October 22, 2010, 11:29:52 am »
I used new rubber gaskets when I did the heads on my truck. The driver side keeps leaking oil.
I tried loosening the bolts incase I had them too tight, and retightening after driving it for a bit. Still leaks.
The truck hardly leaked a thing for a month after I did my heads, now it is. I got underneath and I can see it seeping out from the back of the valve cover and making it's way down the back of the motor.
I have a new set of cork gaskets on the shelf... but I was always told to use rubber.
1986 GMC Sierra Classic
My first truck! (completely stock...for now)
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: Rubber or Cork valve cover gaskets?
« Reply #1 on: October 22, 2010, 11:39:22 am »
If you have them on the shelf go for it.  I wouldn't buy cork, but I'd use em if I had em.  If its still leaking, take the valve cover off and check it to see if its really flat, like on a known flat surface.  tweak it until its flat.  also where the bolt holes are you may need to flatten that area back out as tightened bolts would dimple the area down and ot pull the rest of the flange down enough.  Are you using the spreaders on the bottom bolts?  Maybe a set of wider aftermarket spreaders would help. I pretty much always use em.
The stockers look something like this but aren't chrome.
The aftermarket ones I use look like this
Offline lbrowne
« Reply #2 on: October 22, 2010, 12:18:26 pm »
I'm using wider spreaders, they were already on the truck. (like your bottom pic, but not chrome)
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #3 on: October 22, 2010, 01:53:41 pm »
I used the Fel-Pro cork gaskets with the spreaders and have had pretty good luck. The first set leaked some, but I think I put too much silicone on them. On this set I used 3M adhesive and they are working well. It's really important to make sure your sealing surfaces are smooth and flat like Kenny stated.
Offline lbrowne
« Reply #4 on: October 22, 2010, 02:07:22 pm »
Maybe I'll try pulling that valve cover this weekend, for some reason I remember the driver side valve cover being a pain to remove and get back on.
« Last Edit: October 23, 2010, 10:33:41 am by Captkaos »
« Reply #5 on: October 22, 2010, 02:19:52 pm »
I have tall covers and the booster gets in the way.
« Reply #6 on: October 23, 2010, 10:37:30 am »
You are tightening down on the cork gasket to much.  If it is leaking you can never "loosen" it to make it stop.  You have to get it tighter.  The cork gaskest aren't meant to be clamped down on.  I get them cinched down by had (no ratchet) and then put a small turn on them with tension.
Offline lbrowne
« Reply #7 on: October 23, 2010, 01:54:05 pm »
I have the rubber gaskets on there right now, that's what's leaking. I thought you could overtighten them and cause them to leak.
Maybe I'll throw a cork gasket on there after I check the mating purposes.
Offline HAULIN IT
« Reply #8 on: October 23, 2010, 08:13:48 pm »
Fel Pro makes some with a plastic "framework" with a raised sealing bead that work well & are reusable. They are a bit costly (about $25), but really should be the last ones you'll need. Lorne
Offline Dr_Snooz
« Reply #9 on: October 24, 2010, 02:23:32 pm »
The torque spec on those valve covers is 48 in-lbs. That's not far past wrist tight. If you didn't use a torque wrench, chances are good that you over-tightened them.
« Reply #10 on: October 24, 2010, 09:27:12 pm »
I had a Guy at autozone once get two sets of gaskets I looked at him he said he puts both sets on at once and has never had one leak. Never found out how it turned out nor have I tried it
Offline lbrowne
« Reply #11 on: October 25, 2010, 10:13:23 am »
45 INCH pounds? !?!  I must have them too tight, yikes!
Offline Psycho71
« Reply #12 on: October 25, 2010, 10:19:33 am »
 I like the valve cover gaskets that are rubber with the steel shim in the middle of them. They seem a lot more forgiving to me. I rtv them to the valve cover, then turn them gasket down on a flat surface. Let them sit overnight, then install the valve cover using the spreaders described above, and t-handle bolts. Just good and snug. Then, as a habit, every time I open the hood I check all the t-handles to make sure none have backed off.
Works like a champ for me.
« Reply #13 on: October 26, 2010, 03:49:20 am »
just dont leave the t handles on that can be removed lol ::)
Offline Psycho71
« Reply #14 on: October 26, 2010, 10:05:43 am »
Good point. I use the ones that the "T" is pressed in. Not the Cheaper/uglier "Y" handles that will eventually vibrate off driving down the road.
