Author Topic: Fuel leak  (Read 4198 times)
Offline bigfosty
Fuel leak
« on: October 27, 2010, 07:35:24 pm »
This might sound confusing but I'll try my best to explain it clearly. My passenger side tank is leaking. When I switch to that tank after about 15-20 seconds fuel starts pouring out from the top of the tank. I am assuming this is a fuel line, perhaps a return line given the short wait before fuel starts leaking out. This has been going on since I bought the truck and I haven't bothered to fix it since I have the other tank. Now though it seems when I fill the drivers side tank it starts leaking, but it leaks from the passenger side, from above the passenger tank. It's a much smaller leak than the original one and it seems to either be intermittent, or only leak when there is a certain amount of fuel in my drivers side tank. I haven't driven it enough to be able to tell however if it's intermittent or only leaks when theres so much fuel. Anybody got any ideas? I haven't looked super close due to the weather right now, but it looks like the only way to get a clear view of the lines is to drop the tanks? Anything I need to look out for when doing this? Are the lines long enough to drop the tank without disconnecting them? Thanks for any help guys, much appreciated.
Offline Grim 82
Re: Fuel leak
« Reply #1 on: October 27, 2010, 09:06:33 pm »
I am only speaking for myself, but honestly, after having been there and done that I would remove the bed instead of dropping the tanks. Then get the 3 different sizes of fuel hose and replace every inch of rubber, including the ones for the selector switch.
Offline bigfosty
Re: Fuel leak
« Reply #2 on: October 27, 2010, 09:29:21 pm »
I thought about this but it looked like part of the tanks were under the cab and I would have to drop them anyways. Not the case? It's a 75 k-10 if that makes a difference.
Offline Grim 82
Re: Fuel leak
« Reply #3 on: October 27, 2010, 10:52:22 pm »
The front parts of the tanks extend under the cab, but the hoses and sending unit are accessable without the bed on the pickup.
