Author Topic: having problems keep it running  (Read 3703 times)
Offline Buddy
« on: October 29, 2010, 05:04:19 am »
I am building an 85 4x4 gmc. It has a 305 with an eldbrock dome and a 600 holly carb on it. My problem is that the truck starts somewhat good but doesn't ever seem to stay running at idle. I always have to play with throtle to keep it going. I see people saying that it could be the timing, not sure how to do that yet. Next thing I hear people saying is that it could be the vacum advance. I cant seem to find the vacum adavnce on my truck. dont know if that because everything is aftermarket or what. Any advice would be great!
Offline jaredts
Re: having problems keep it running
« Reply #1 on: October 29, 2010, 07:11:35 am »
Does it idle poorly when its cold or all the time regardless of temp.?
Offline Buddy
« Reply #2 on: October 29, 2010, 07:26:31 am »
i am not running thos truck as of yet, still in the build process. so it is just when i start it and try to run it in the shop
Offline jaredts
« Reply #3 on: October 29, 2010, 12:26:03 pm »
There's at least a hundred things it could be!  Need to know what you've done so far and what kind of carburetor/condition of carburetor.  Once everything is right (choke adjustment, timing, no vacuum leaks) the idle speed screw should be run up to a proper idle speed.  If you haven't yet, you might let the engine get to temp. and see how it idles.
