Author Topic: interchange guide  (Read 7962 times)
Offline project85
interchange guide
« on: October 29, 2010, 05:05:28 am »
Hey everybody,
I'm new to the site and also a new owner of an 85 c-10. Excited to start tearing down so I can build it back up. I wanted to ask is the any good interchange books out there or is it safe that most parts from 81 to 87 will swap and fit my 85?? Thanks
1985 C-10 Deluxe Step Side
Re: interchange guide
« Reply #1 on: October 29, 2010, 06:39:33 am »
Pretty much all 81-87 interchange.  84 on up for steering column and dash.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: October 29, 2010, 10:03:29 am »
welcome and good luck on your project.
Offline jaredts
« Reply #3 on: October 29, 2010, 12:28:33 pm »
Welcome.  Once you've been reading through this site for a while you'll get the idea of what things changed and when.  Any questions just post 'em up and someone here will know.
Offline project85
« Reply #4 on: October 29, 2010, 02:26:32 pm »
thanks. this truck is an 85. the steering column has the wipers, high beams on the directional lever. is this right or is it an aftermarket or newer column? it has a 3 speed on the floor. under the hood i can see where it looks like it was a column shift manual transmission originally. any input would be great. thanks
« Reply #5 on: October 29, 2010, 04:12:45 pm »
Yes, the integrated wiper/dimmer switch started in 1984 so yours is correct to the truck.
Offline project85
« Reply #6 on: October 29, 2010, 04:44:44 pm »
awsome thanks. i'll probably be asking all kinds of questions for a few months getting up to speed with this truck.
thanks
« Reply #7 on: October 29, 2010, 10:32:25 pm »
Three speed stick only came on the column. The SM465 has 4 gears but is really a 3 speed with low. They are on the floor.
Welcome from New Hampshaa.
Offline project85
« Reply #8 on: October 30, 2010, 06:02:58 am »
It looks like the guy before me converted the 3speed on the column to the floor. Hopefully he did it right and I won't have to back track that too.
« Reply #9 on: October 31, 2010, 12:33:06 am »
90% of those floor shifters even when done right are junk!
Offline project85
« Reply #10 on: October 31, 2010, 06:29:28 am »
i know the 3 speed is horrible  >:(. it seems to work and shift fine just not very fun to drive. you have to reach so far to go to second gear. i rather be pulling second down then pushing it under the ash tray. i'll definetily be putting a 4 speed in at some point.
