Author Topic: Where to Buy Ring and Pinion  (Read 3954 times)
Offline Da67goatman
  • Burban
« on: October 29, 2010, 10:48:21 am »
I want either a 3.42 or 3.21 ratio for my 14 bolt full floater, but I can't find any place that has any that go low enough.  They seem to stop at 3.73.  I will be checking local junkyards, but other than them any one know where to get gears?  Thanks.
<Pitcrew>
Offline Grim 82
Re: Where to Buy Ring and Pinion
« Reply #1 on: October 29, 2010, 11:15:34 am »
I think that out of anybody, Randy's Ring & Pinion would be the most likely to have it, if anybody makes it. Or, pick up an issue of 4 wheel & off-road and check the ads in the back for suppliers.
Offline Da67goatman
  • Burban
« Reply #2 on: October 29, 2010, 11:40:12 am »
WOW! Randy's has 3.42 but their 4 and 5 HUNDRED dollars.  OUCH!  I can't spend that much on them because its real awkward when people ask what the most expensive part of your truck is and you respond with the ring and pinion.
I just got the latest Peterson's 4 Wheel and Off-road and and they didn't have any vendors other than Randy's.
Thanks for the ideas, keep em comin.
<Pitcrew>
Offline Grim 82
« Reply #3 on: October 29, 2010, 12:01:28 pm »
Liberty gear or Yukon gear maybe. I don't know what size ring gear you would have but here's one set.
http://rearendparts.com/home.php?cat=372
