73-87 Chevy & GMC Trucks
Throttle Adjustment
Topic: Throttle Adjustment (Read 3788 times)
Da67goatman
Site Supporters
Burban
Throttle Adjustment
October 30, 2010, 07:07:51 am »
My pedal does not pull the throttle all the way open, is there some way to adjust it? The pedal hits the floor at about 3/4 throttle. Thanks in advance.
<Pitcrew>
1992 fullsize Blazer 4x4 35s no lift, 4.10s, Hella driving lights, TJ Flares, Huge bumpers, Snorkel, custom interior
Dr_Snooz
"I like to take hammers, and just break stuff"
Re: Throttle Adjustment
October 31, 2010, 12:15:37 am »
I would start by making sure that you don't have any bent brackets or arms. If that all checks out, look into buying a new adjustable throttle cable from Kragen. I used a Spectre one off the shelf.
October 31, 2010, 04:28:31 am »
The cable you should have to adjust I would look at something to do with the carb even if your bracket is bent you still should have the same throttle movement
Da67goatman
Site Supporters
Burban
October 31, 2010, 09:53:08 am »
Its all factory stuff from cable to throttle body. I'll see if its bent anywhere. Is there no adjust-ability from the factory?
<Pitcrew>
Grim 82
October 31, 2010, 12:49:19 pm »
I bent the arm at the pedal to get a little more travel on mine. Just don't break it where it pivots at the floorboard.
Throttle Adjustment
