Author Topic: 350 Backfiring problem  (Read 32196 times)
Offline my78chevyc10
« on: November 01, 2010, 06:10:09 pm »
Hello, my 1978 Chevy C10 is my daily driver to high school and it has a Chevy 350 5.7l  is a pretty bare block with little electronics but it has headers and an Edelbrock intake and carb and a Delco HEI Distributor. The backfire is through the exhaust not the carb and happen when the throttle is opened up from idle (roughy 800 rpms) This started to happen after I changed the plugs, plug wires and removed the header to get the plugs. Any ideas on how to fix it would be great! Thanks. :)
Offline TexasRed
Re: 350 Backfiring problem
« Reply #1 on: November 01, 2010, 06:22:30 pm »
Double check the plug wires to make sure they are tight on the plugs and distributor and that you haven't crossed any. Also make sure there are no exhaust leaks. But I'm guessing some plug wires are crossed.
Offline ITSANSS
« Reply #2 on: November 01, 2010, 06:23:06 pm »
Probably the most likely cause is a crossed spark plug wire.
Have you triple checked that the spark plug wires are to the correct spark plugs?
Good luck
edit: TexasRed, ya' beat me to it.   :D
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #3 on: November 01, 2010, 06:23:59 pm »
Could be a header leak.  Did you put a new gasket on the header?   may also be bad timing.   could you have moved the distributor while doing the plug wires?   are all the plugs in there tight?  i have left one loose before ;D
and are all the plug wires loosly installed (as in none of them pulled tight anywhere)  and did you stretch any of them at all?  sometimes that will break the conductor while the insulator looks good.
An exhaust backfire is either a leak:  it lets the cylinder suck air back into the cylinder causing a lean condition.
or a cylinder not firing all the time or at the wrong time:  unburnt fuel builds up in the pipe and then backfires when the stuff in the pipe actually ignites.
Checked everything and seems fine.
« Reply #4 on: November 03, 2010, 05:24:40 pm »
Thanks for all the quick replies guys. I checked my timing order and even checked that all my plug wires were snug and all seems to be okay. These plugs have a larger gap than before with a .45 gap whereas my others were .40 which I've read runs fine with an HEI distributor. I have new exhaust gaskets on the way and am hoping that is the issue. When going to a larger gap is it necessary to rotate the distributor any? Thanks.
Offline elixeric10
« Reply #5 on: November 03, 2010, 05:29:36 pm »
well a easy  way to test this out is to put your old plugs back in if that dont work try messing with your timing .. just something i would try
Offline motion427
« Reply #6 on: November 03, 2010, 05:41:20 pm »
You might have a bad plug,if everything else is good.
Somebody might have dropped the plug on the floor or something and cracked it.
Since you have the old ones,could try them again.Maybe just do one side at a time.
86 K10,350 Roller Cam,T350,NP205,10 bolt posi,12 bolt posi,33" tires.
85 K30,454,T400,NP205,Dana 60,14 bolt,being built now.
04 Avalanche Z71,6.0L,TVS 1900,Dynatech,Corsa,etc...
06 TBSS,AWD,6.0L,Kooks,C6 fan kit,etc...
75 Nova SS,502,T350,12 bolt
Offline Grim 82
« Reply #7 on: November 03, 2010, 08:11:21 pm »
No. Wouldn't hurt to slowly go back to what was there before the problem and see if you can track it down. You can never visually inspect a plug wire for conductivity.
« Last Edit: November 03, 2010, 08:15:51 pm by Grim 82 »
Checked it out again.
« Reply #8 on: November 03, 2010, 08:21:33 pm »
Well I advanced the timing on the distributor which made it run a lot smoother for some reason with no knocking but still afterfiring. It looks as if some black is starting to form around cylinder 2 exhaust header, I guess it's good thing I ordered those gaskets. I would love to try my old plugs, but I made the stupid/novice choice of throwing them away...  :( If it is a header leak causing the problem it still doesn't make sense that the fuel is making it's way through the exhaust and exploding. Thanks.
Offline Grim 82
« Reply #9 on: November 03, 2010, 08:26:26 pm »
It makes sense if that cylinder isn't getting spark to burn the fuel because of a bad plug or wire....
Offline TexasRed
« Reply #10 on: November 03, 2010, 10:28:18 pm »
Actually, in most exhaust there's enough hydrocarbons to keep combusting. That's what the air pump does, it pumps air into the exhaust manifolds and the gas still there burns a little more. High heat helps there too. So, it sounds like maybe it's the gaskets.
Offline Grim 82
« Reply #11 on: November 03, 2010, 10:49:37 pm »
Yes, replace the gaskets for sure but if that doesn't do it look back at what you swapped out at the time when the problems started.
« Reply #12 on: November 04, 2010, 08:02:08 am »
Get them aluminum ones from autozone in their "performance" section if a bolt backs out with the paper ones the will blow threw it and new gaskets are needed with aluminum ones you can reuse them and if a bolt backs out it wont blow out just really tighten the bolt
Replaced gaskets
« Reply #13 on: November 04, 2010, 07:13:00 pm »
Well guys I replaced my exhaust gaskets and torqued down the header correctly and still the same thing. I guess it's time to go buy some new plugs and try my old wires that I actually kept. I really hope this solves my issue... When I pulled the header off, it looked like my cylinder 2 was kinda oily/wet I don't know exactly what that means but I did notice that.
Offline Grim 82
« Reply #14 on: November 04, 2010, 07:16:33 pm »
What does the plug look like in that cylinder?
