Author Topic: 350 build  (Read 76405 times)
Offline screamin86
Re: 350 build
« Reply #60 on: December 29, 2010, 11:57:55 pm »
pretty much same specs you will like it!
86 ta:lm7 hot cam boltons
Offline 1980c10
Re: 350 build
« Reply #61 on: January 07, 2011, 05:24:00 pm »
Update;
short block assembled, painted cast iron gray, timing chain and cover installed, intake gasket, headers, clutch, water pump, fuel pump are now here.
I need to get the valve covers sanded and polished.
-I also would like to buy a new distributor, i am looking for a complete unit with cap and coil cover, non computer and with vacuum adv. anyone know a good source???
-Also looking for some good universal plug wire with 90 degree plug caps
(going to run them below the headers)
I hope to dyno this engine in the next week or two.
hoping to get this thing dialed in just right with the right jet and adv spring etc.
I will post back the results here. any guesses?
Offline 1980c10
« Last Edit: January 07, 2011, 05:32:56 pm by 1980c10 »
Offline TexasRed
Re: 350 build
« Reply #63 on: January 07, 2011, 07:28:20 pm »
I'm a little leery of skip white. I need to switch out fuel pumps and throw the pro-comp I got from him in the trash. You can go to summit too.
http://www.summitracing.com/parts/SUM-850001R/
They don't come with plug wires however. They sell a combo kit too but I bet it's over the valve cover style. If you're getting long tube headers, the MSD wires for corvette with headers won't be long enough to go under headers. At least they didn't on mine.
Offline 1980c10
Re: 350 build
« Reply #64 on: January 07, 2011, 08:14:49 pm »
I like the one from summit.
The parts stores around here get about 140 for a complete accel or msd distributor and thats with a red or blue cap(I want a black cap since I want to hide the wires)
So I would have to spend a little more to get it the way I want.
I wasn't looking for a combo kit. I just happened to like those wires. summit has the same wires for $99 so it's kind of like getting a free distributor. with that deal.
As far as the wires go; I will most likely get a universal set as they will have long enough wires.
btw: I have these headers
http://www.summitracing.com/parts/BIG-31500FLT/
Offline 1980c10
Re: 350 build
« Reply #65 on: January 15, 2011, 06:15:36 pm »
I ended up getting a proform distributor and a set of msd streetfire universal with 90 degree plugs. I will run this on the dyno next week
Offline screamin86
Re: 350 build
« Reply #66 on: January 16, 2011, 09:18:49 am »
I'm kinda curious on the numbers it will make.
Offline 1980c10
Re: 350 build
« Reply #67 on: January 18, 2011, 08:18:42 pm »
dyno'd today  8)
specs: 350 .030 over
vortec heads, a/c delco platinum
fat top pistons, 9.7 ish to 1 compression ratio
crower torque beast cam
intake edelbrock performer, 1 inch open spacer
carb holley 670 avenger, jets: Changed to P-68 S-72   From the box: P-65 S-68
proform dist, msd streetfire wires.
vacuum adv connected
Balanced rotating assembly
timing adv: 31 degrees
rpm 3000-5500
91 octane pump gas
« Last Edit: January 18, 2011, 09:06:14 pm by 1980c10 »
Offline 1980c10
Re: 350 build
« Reply #68 on: January 18, 2011, 08:32:27 pm »
Peak torque: 431.6 @ 4300
peak HP: 393.3 @ 5400
rpm         tq            hp
3000      401          229
3100      404          239
3200      409          250
3300      412          259
3400      414          268
3500      416          277
3600      420          288
3700      422          297
3800      422          305
3900      423          314
4000      424          323
4100      427          334
4200      431          345
4300      432          353
4400      431          361
4500      429          368
4600      428          375
4700      424          380
4800      420          384
4900      415          387
5000      409          390
5100      404          392
5300      389          393
5400      374          393
5500      374          392
Offline Layne
Re: 350 build
« Reply #69 on: January 18, 2011, 08:33:07 pm »
Nice!
Offline screamin86
Re: 350 build
« Reply #70 on: January 18, 2011, 08:39:11 pm »
Wow those are some great numbers! Congrats!
Offline Grim 82
Re: 350 build
« Reply #71 on: January 18, 2011, 08:50:01 pm »
That's awesome man
Offline 1980c10
Re: 350 build
« Reply #72 on: January 18, 2011, 08:56:35 pm »
the quadrajet had major problems.
ran a 770 cfm holley from the dyno shop and a 670-both worked great, needed bigger jets in the 670 to run the same numbers as the 770.
I kept the 670 for better throttle response since both run the same.
I will deal with the q-jet carb guy tomorow, couldn't even hold 2000 rpm to break the cam in.
He supposedly run this on his test engine.
otherwise the engine ran perfect, no leaks, no noise perfect 62-70 oil psi through the rpm range.
I can probably run this engine on 87 octane as it is only 31 degrees advanced.
The 1" open spacer added 8-9 hp this worked becuase it evened out the a/f mixture left to right.
Dyno guy and engine builder were both impressed with the vortech heads and agree'd that these were probably good for 30 hp.
« Last Edit: January 18, 2011, 09:23:25 pm by 1980c10 »
Offline 1980c10
Re: 350 build
« Reply #73 on: January 18, 2011, 09:01:16 pm »
Offline eventhorizon66
Re: 350 build
« Reply #74 on: January 19, 2011, 02:00:42 pm »
Awesome!  Aren't you glad you went with the vortec heads? ;)  Now the trick will be getting the engine running in the truck with minimal power loss (exhaust, accessories, underhood heat, transmission, rotating mass, etc.).
Some interesting reading on the subject:
http://www.popularhotrodding.com/tech/0602phr_rear_wheel_power_increase/index.html
http://www.superchevy.com/technical/engines_drivetrain/exhaust/0505phr_exh/index.html
Shame about the Q-jet.  There is no good reason why a properly rebuilt/calibrated Q-jet can't run as good as or better than that 670 Holley.
« Last Edit: January 19, 2011, 02:16:42 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
