350 build
4
5
6
Topic: 350 build (Read 76419 times)
screamin86
Re: 350 build
Reply #60 on:
December 29, 2010, 11:57:55 pm »
pretty much same specs you will like it!
86 ta:lm7 hot cam boltons
1980c10
Re: 350 build
Reply #61 on:
January 07, 2011, 05:24:00 pm »
Update;
short block assembled, painted cast iron gray, timing chain and cover installed, intake gasket, headers, clutch, water pump, fuel pump are now here.
I need to get the valve covers sanded and polished.
-I also would like to buy a new distributor, i am looking for a complete unit with cap and coil cover, non computer and with vacuum adv. anyone know a good source???
-Also looking for some good universal plug wire with 90 degree plug caps
(going to run them below the headers)
I hope to dyno this engine in the next week or two.
hoping to get this thing dialed in just right with the right jet and adv spring etc.
I will post back the results here. any guesses?
1980c10
Re: 350 build
Reply #62 on:
January 07, 2011, 05:29:21 pm »
Anybody try ebay distributors? results? Recommendations?
How about this one?
http://cgi.ebay.com/ebaymotors/SBC-CHEVY-HEI-DISTRIBUTOR-AND-ACCEL-300-WIRES-6500-R-K-_W0QQcmdZViewItemQQhashZitem5196dd8044QQitemZ350423449668QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Last Edit: January 07, 2011, 05:32:56 pm by 1980c10
TexasRed
Re: 350 build
Reply #63 on:
January 07, 2011, 07:28:20 pm »
I'm a little leery of skip white. I need to switch out fuel pumps and throw the pro-comp I got from him in the trash. You can go to summit too.
http://www.summitracing.com/parts/SUM-850001R/
They don't come with plug wires however. They sell a combo kit too but I bet it's over the valve cover style. If you're getting long tube headers, the MSD wires for corvette with headers won't be long enough to go under headers. At least they didn't on mine.
1980c10
Re: 350 build
Reply #64 on:
January 07, 2011, 08:14:49 pm »
I like the one from summit.
The parts stores around here get about 140 for a complete accel or msd distributor and thats with a red or blue cap(I want a black cap since I want to hide the wires)
So I would have to spend a little more to get it the way I want.
I wasn't looking for a combo kit. I just happened to like those wires. summit has the same wires for $99 so it's kind of like getting a free distributor. with that deal.
As far as the wires go; I will most likely get a universal set as they will have long enough wires.
btw: I have these headers
http://www.summitracing.com/parts/BIG-31500FLT/
1980c10
Re: 350 build
Reply #65 on:
January 15, 2011, 06:15:36 pm »
I ended up getting a proform distributor and a set of msd streetfire universal with 90 degree plugs. I will run this on the dyno next week
screamin86
Re: 350 build
Reply #66 on:
January 16, 2011, 09:18:49 am »
I'm kinda curious on the numbers it will make.
1980c10
Re: 350 build
Reply #67 on:
January 18, 2011, 08:18:42 pm »
dyno'd today
specs: 350 .030 over
vortec heads, a/c delco platinum
fat top pistons, 9.7 ish to 1 compression ratio
crower torque beast cam
intake edelbrock performer, 1 inch open spacer
carb holley 670 avenger, jets: Changed to P-68 S-72 From the box: P-65 S-68
proform dist, msd streetfire wires.
vacuum adv connected
Balanced rotating assembly
timing adv: 31 degrees
rpm 3000-5500
91 octane pump gas
Last Edit: January 18, 2011, 09:06:14 pm by 1980c10
1980c10
Re: 350 build
Reply #68 on:
January 18, 2011, 08:32:27 pm »
Peak torque: 431.6 @ 4300
peak HP: 393.3 @ 5400
rpm tq hp
3000 401 229
3100 404 239
3200 409 250
3300 412 259
3400 414 268
3500 416 277
3600 420 288
3700 422 297
3800 422 305
3900 423 314
4000 424 323
4100 427 334
4200 431 345
4300 432 353
4400 431 361
4500 429 368
4600 428 375
4700 424 380
4800 420 384
4900 415 387
5000 409 390
5100 404 392
5300 389 393
5400 374 393
5500 374 392
Layne
Re: 350 build
Reply #69 on:
January 18, 2011, 08:33:07 pm »
Nice!
screamin86
Re: 350 build
Reply #70 on:
January 18, 2011, 08:39:11 pm »
Wow those are some great numbers! Congrats!
Grim 82
Re: 350 build
Reply #71 on:
January 18, 2011, 08:50:01 pm »
That's awesome man
1980c10
Re: 350 build
Reply #72 on:
January 18, 2011, 08:56:35 pm »
the quadrajet had major problems.
ran a 770 cfm holley from the dyno shop and a 670-both worked great, needed bigger jets in the 670 to run the same numbers as the 770.
I kept the 670 for better throttle response since both run the same.
I will deal with the q-jet carb guy tomorow, couldn't even hold 2000 rpm to break the cam in.
He supposedly run this on his test engine.
otherwise the engine ran perfect, no leaks, no noise perfect 62-70 oil psi through the rpm range.
I can probably run this engine on 87 octane as it is only 31 degrees advanced.
The 1" open spacer added 8-9 hp this worked becuase it evened out the a/f mixture left to right.
Dyno guy and engine builder were both impressed with the vortech heads and agree'd that these were probably good for 30 hp.
Last Edit: January 18, 2011, 09:23:25 pm by 1980c10
1980c10
Re: 350 build
Reply #73 on:
January 18, 2011, 09:01:16 pm »
This is the new carb:
http://www.summitracing.com/parts/HLY-0-80670/
eventhorizon66
Re: 350 build
Reply #74 on:
January 19, 2011, 02:00:42 pm »
Awesome! Aren't you glad you went with the vortec heads?
Now the trick will be getting the engine running in the truck with minimal power loss (exhaust, accessories, underhood heat, transmission, rotating mass, etc.).
Some interesting reading on the subject:
http://www.popularhotrodding.com/tech/0602phr_rear_wheel_power_increase/index.html
http://www.superchevy.com/technical/engines_drivetrain/exhaust/0505phr_exh/index.html
Shame about the Q-jet. There is no good reason why a properly rebuilt/calibrated Q-jet can't run as good as or better than that 670 Holley.
Last Edit: January 19, 2011, 02:16:42 pm by eventhorizon66
'85 C10 SWB 350
700R4
TKO600
4
5
6
350 build
