Author Topic: Repost: power loss issue  (Read 94151 times)
Offline nativetexan
Re: Repost: power loss issue
« Reply #135 on: September 14, 2011, 08:13:52 am »
So any ideas on my vacuum gauge readings?
http://imageshack.us/clip/my-videos/535/r7d.mp4/
Here is a video of it.
Idle seems good. When I barely push on the throttle, the engine starts to shake and then as I increase throttle it goes away. When I hit the throttle real hard, it sounds like it is backfiring in the tbi or manifold. When I increase throttle gradualy up to wherei it starts to bog, it seems like it backfires out the muffler when I let go of the throttle.
« Last Edit: September 14, 2011, 03:06:21 pm by nativetexan »
Offline nativetexan
« Reply #136 on: September 15, 2011, 09:17:06 pm »
Anyone?
Offline rsandusky
« Reply #137 on: September 16, 2011, 09:50:59 am »
Vaccum guage looks pretty normal.  :)
That tells us that the rings and valves are sealing. Also I think we can rule out a plugged exhaust.
I would check the Throttle position sensor and also the M.A.P. sensor for a bad spot with a analog meter.
Offline nativetexan
« Reply #138 on: September 18, 2011, 12:01:30 pm »
I do question the MAP. I tested the TPS and it ohm'd to specs with a meter.
« Reply #139 on: September 18, 2011, 07:02:40 pm »
i wsa working on a geo oncecant remember what it was doing but i unplugged the map problem didnt change swapped it with one of another truck fixed the problem
Offline nativetexan
« Reply #140 on: September 19, 2011, 09:52:27 pm »
Well, I did unplug it and it did get worse, but I will try to find another one. It might just be failing in that particular range huh?
« Reply #141 on: September 20, 2011, 12:00:02 am »
only had it fail 100% not in a particular range
Offline jasong
« Reply #142 on: April 10, 2012, 10:32:39 am »
Native, just wondering if you found your problem? I have the exact same thing going on in my 89 V3500 with 454tbi, I have replaced all kinds of parts and still nothing. I am starting to wonder about the TPS but wondered if you come up with anything.
