Author Topic: Speedometer Cable length  (Read 25987 times)
Offline bravo1616
« on: November 07, 2010, 09:57:29 am »
I need to replace the speedometer cable on my 82 GMC K1500. It has cruise control and I only have to replace the lower cable, the one from the transducer to the transfer case.
Does anyone know how long it is or where I can find that information, I would like to get one ready to go. Thanks for any replies.
« Last Edit: November 07, 2010, 11:25:36 am by bravo1616 »
1982 GMC K1500 Sierra Classic 383 Stroker 4" Rough Country Lift
Offline bravo1616
Re: Speedometer Cable length
« Reply #2 on: November 07, 2010, 01:27:16 pm »
« Last Edit: November 07, 2010, 01:30:33 pm by bravo1616 »
« Reply #3 on: November 07, 2010, 05:39:37 pm »
Don't know why I thought it was a 85 lol
Offline bravo1616
« Reply #4 on: November 07, 2010, 07:09:17 pm »
Hey Irish_Alley,
They only had 83" with the fittings so that's what I got, but now it looks like the trouble is with the cruise control transducer. I connected the cable at the transducer and it doesn't spin...isn't that how it always goes.  :(
Offline bravo1616
« Reply #5 on: November 07, 2010, 07:12:26 pm »
and the Cruise Control Transducer is $100...bummer, the cable was only $12...looks like I will bypass the transducer for now.
« Last Edit: November 07, 2010, 07:15:02 pm by bravo1616 »
« Reply #6 on: November 07, 2010, 09:40:24 pm »
The previous owner threw out the transducer in my truck, so i got one at the junk yard.  i dont need the cruise, just wanted my speedo to work again.
« Reply #7 on: November 08, 2010, 04:07:46 am »
x2 save some cash and get one from the yard
Offline bravo1616
« Reply #8 on: November 08, 2010, 10:26:23 am »
I'll check the junk yard this week - thanks guys.
Offline Grim 82
« Reply #9 on: November 09, 2010, 11:25:29 am »
I don't care for cruise, and my transducer was bad, so I went to O'reillys and bought the cable for my pickup but specified a model without cruise control. I got the longest of the choices and ran it directly from the t-case to the speedometer.
Offline bravo1616
« Reply #10 on: November 09, 2010, 11:46:22 am »
that's what I'm leaning towards, were you able to reach under the dash or did you have to take the instrument panel off to get to the back of the speedometer?
Offline Grim 82
« Reply #11 on: November 09, 2010, 01:09:28 pm »
You have to remove the instrument panel. Disconnect the cable from the transducer first.
Offline bravo1616
« Reply #12 on: November 09, 2010, 01:18:59 pm »
Is this the right length cable and fittings? or there is one that's 80 inches, CA-3001.
« Last Edit: November 09, 2010, 01:20:52 pm by bravo1616 »
Offline Grim 82
« Reply #13 on: November 09, 2010, 02:19:19 pm »
100" sounds about right, you're looking for the longest one available if bypassing the transducer.
Offline bravo1616
« Reply #14 on: November 09, 2010, 02:37:01 pm »
and are those fittings correct, there is only one end with the hose type fitting that goes into the trannsmission, the other end doesn't seem to have that.
