Author Topic: Electric doors conversion. Help needed..  (Read 14360 times)
Offline lpapa15
  • 1979 k10 silverado
« on: November 09, 2010, 06:32:35 pm »
I am from manual to power on my truck.  I have been working for two days trying to get some juice to my doors.  Heres what i have done so far.  I bought two doors from different suburbans and took all the wiring that ran between the two.  Anything that was attached to the wiring for the door i took.  I even looked over a suburban truck and studied the wiring to the fuse box.   That truck had two wires from the doors running to a power source.  I really have no idea what i am doing.  I have been trying to get power to just one door (passenger) and I can't get anything.  I checked the fuses and all the wiring and It seems to look good, but nothing..  I have no idea where to go now. I am about to call an electrician and have him come over to fix it right.   Any ideas?  Please help.  If you have converted to power from manual I would love to know how you did it.  Please help.  My truck is a 79 k10 and the doors are from a 90 suburban.
Offline ccz145a
Re: Electric doors conversion. Help needed..
« Reply #1 on: November 09, 2010, 07:23:46 pm »
Pretty sure the driver's switch needs to be hooked up. Get a voltmeter or test light and make sure the power is where it needs to be.
« Last Edit: November 09, 2010, 07:25:19 pm by ccz145a »
Offline 1980c10
« Reply #2 on: November 09, 2010, 11:26:58 pm »
get a multi-meter,
turn it to dc volts, check for power at your source in the fuse block-it should be powered with the key on and no power with the key off, if you dont then find a source that does, if you do then the rest is just running wires and connecting to your switches and motors. electrical troubleshooting is just about narrowing your focus.
so check;
-power from your source
-power at your switch
-power at your motor
in that order.
Offline lpapa15
« Reply #3 on: November 10, 2010, 04:05:52 pm »
in your experience does the drivers side door need to be connected in order for the passenger door to work?  I have been trying the passenger door only.
Thanks for the help.
Offline ccz145a
« Reply #4 on: November 10, 2010, 04:30:26 pm »
Yes
